Date: 07-05-26  Time: 07:56 am
Author Topic: Brake Reservoir hose ID  (Read 2718 times)
Adam2201
« on: 26 February 2016, 10:40:15 am »
Has anyone ever had to replace the rubber hose from the brake reservoir to the rear master cylinder?  I noticed a bit of brake fluid on mine today - it could just be that the reservoir was just disturbed when I fitted my stainless hoses so I will check the clamps and have another look at it tomorrow, but since the rubber is likely to be original to the bike it can't be a bad idea to replace it at 17 years old, even if it's not under great pressure.
I wouldn't mind paying £10.00 for a Yamaha part from Fowlers or AJ Sutton, but as it's on special order from Japan, I'm wondering if anyone happens to know the internal diameter of the hose so I can just order a metre of rubber brake hose to cut down?
I'm guessing from the part number:
5DM-25895-00
it's 3/8 ID (9.5mm)?  the 5DM is the bike designation and the 258 seems to be 'brake hose' looking at similar parts?
Many thanks in advance.
