Date: 05-05-26  Time: 10:33 am
Author Topic: clutch  (Read 2128 times)
Metal Merv
clutch
« on: 17 February 2016, 09:39:26 pm »
I find my clutch engages as soon as I let lever out.it does it with std levers or after market ones.the bike has done 15,450 miles.i am able to select neutral easily plus other gears.the clutch doesn't slip or creep forward if held in gear.only had the bike 3 weeks.any ideas any body.thanks.
PaulSmith
Re: clutch
« Reply #1 on: 18 February 2016, 10:29:00 am »
The clutch cable is adjusted at both ends. The other adjuster is on the clutch cover (by your right ankle). Loosen it off a little to change the bit point.
Metal Merv
Re: clutch
« Reply #2 on: 18 February 2016, 08:36:15 pm »
re my clutch.thanks paul had a feeling that my be the prob coz of the low mileage.i did have tank off couple of weeks ago but couldn't get to adjuster.i pulled the wires to the side but not lot of help.i also undone the the 2 bolts that bolt it to case but still unable to get to it.it seems I am going to have to take airfilter off so I can move the wires that run up the side of filter on inside of frame.thanks.
PieEater
Re: clutch
« Reply #3 on: 19 February 2016, 06:18:22 am »
I don't think that is the adjuster that PaulSmith is referring to,  however there are actually 3  adjustment points and I think you are looking at the one in the middle of the cable?  Pat's site has some more information and pictures - http://www.cartestsoftware.com/fz1/clutchcableadjustment.html
PaulSmith
Re: clutch
« Reply #4 on: 19 February 2016, 01:36:42 pm »
The one I was talking about is just in front of the black oil filler cap and needs a 10mm spanner if my memory serves. I don't remember a third adjuster in the cable but I could be wrong.
Metal Merv
Re: clutch
« Reply #5 on: 21 February 2016, 07:20:17 pm »
re my clutch prob.i have sorted it now.the problem was the adjusting nut at the engine end of the cable was on the wrong side of the cable bracket.removed cable from bracket put nut other side slight adjustment and job sorted.never saw another adjuster in line of cable.not an easy job to do with the wires in the way and the little bracket on inside of left of frame.done it at black arts suspension workshop so mick caswells hands got in there with me.bit of info for you if you want suspension set up on your fazer he very helpful.thanks for help fellow fazer boys.
