Date: 20-04-26  Time: 23:43 pm
Author Topic: Fazer 2002 .What RPM doing Carburetor Synchronization?  (Read 3132 times)
Irmantas
« on: 13 February 2016, 07:37:15 pm »
Hello my friends. What RPM have to be doing  Carburetor Synchronization? 1050-1150?
Irmantas
Re: Fazer 2002 .What RPM doing Carburetor Synchronization?
« Reply #1 on: 13 February 2016, 07:58:56 pm »
and maybe someone have pictures wheare is that three hiding bolts?:))
Falcon 269
« Reply #2 on: 13 February 2016, 09:52:31 pm »
1150 - 1250 is a better idle speed and that's what I use for carb synch.
No pictures - too dark!  You need a flashlight to search for the synch screws but they are there to be found. :)
Motopsycho87
« Reply #3 on: 14 February 2016, 06:31:40 am »
Ordered some gauges for mine today. It won't even idle properly below 1500rpm so def needs doing...
PieEater
« Reply #4 on: 14 February 2016, 07:36:23 am »
Pat's site has a section on synching the carbs with some pictures which might help - http://www.cartestsoftware.com/fz1/carburetorsynchronization.html
Irmantas
« Reply #5 on: 14 February 2016, 08:07:03 am »
ok , thanks for help friends ;) , just one more question , what RPM have to be on free engine running ? "no acceleration"
PieEater
« Reply #6 on: 14 February 2016, 08:51:41 am »
What Falcon 269 said 1150 - 1250rpm
slappy
« Reply #7 on: 14 February 2016, 10:05:27 am »
You will need a long screwdriver to reach all the adjusting screws :)
Irmantas
« Reply #8 on: 14 February 2016, 04:47:50 pm »
i mean what rpm have to be after synchronization  :rolleyes
Falcon 269
« Reply #9 on: 14 February 2016, 08:40:40 pm »
1200rpm is good.  A bit higher than Yamaha say but keeps the oil pressure up at idle.  :)
PaulSmith
« Reply #10 on: 15 February 2016, 11:29:45 am »
To find the middle screw can be a challenge. Look for the metal bracket with the section cut out between the middle carbs. Now shine your torch over the connectors on your coil through that notch. If you look along the beam of light, you should be able to see the screw.
markie_wales
« Reply #11 on: 15 February 2016, 12:15:28 pm »
Yeah it's all coming back to me now! The last 9 years on KTM's with one, sticking out easy to find, screw has spoilt me
Irmantas
« Reply #12 on: 16 February 2016, 08:56:49 am »
Roger that  :D  . And what synchronizer you reccomend ? bottle or clear plastic vinyl tube ?  :rolleyes
PaulSmith
« Reply #13 on: 16 February 2016, 11:25:45 am »
I prefer the rods to the dials, but that is because I have had my carbtune for years and have never used one of the others. I don't think there is a big difference between them.
