Date: 08-05-26  Time: 00:47 am
Author Topic: Front Sprocket Nut & Lockwasher Part Nos  (Read 4289 times)
Dave48
« on: 10 February 2016, 10:30:40 am »
Recently ordered the 12mm nut & tab washer upgrade  kit from my local dealer.
The combined kit carries the Yamaha part no 90891-10124 & retails @ £2-44.
However the kit contained the 2 individually wrapped items and the respective part nos are:
12mm Nut   part no. 90179-18006
Tab washer    "   "     90215-21290
I only mention this because the modification kit & the 12mm nut are not on the normal microfiche pages but if you quote the part nos above they can be located & obtained.
Punkstig
Re: Front Sprocket Nut & Lockwasher Part Nos
« Reply #1 on: 10 February 2016, 11:57:11 am »
Have you measured the nut?
I've just changed my c&s, went to local yam dealer for the new nut which as far as we could work out has been superceded again but by a 10mm nut!
« Reply #2 on: 10 February 2016, 12:16:27 pm »
Why would they go 10mm from 12mm, that's just daft?
Punkstig
« Reply #3 on: 10 February 2016, 12:17:58 pm »
I know, that's why I'm asking if he's measured it- I'd assume the 12mm is still available but I didn't have the correct part number at the time and the 10mm (measured myself) is the one on the computer system)
« Reply #4 on: 10 February 2016, 12:59:56 pm »
I have a spare nut and washer kit (90891-10124) one at home, I will measure it this evening and let you know.
« Reply #5 on: 10 February 2016, 01:28:31 pm »
That code is for the 12mm one, i've seen it enough times on here.
« Reply #6 on: 10 February 2016, 01:29:33 pm »
Every little helps, as they say, i s'pose!
Dave48
« Reply #7 on: 10 February 2016, 05:37:28 pm »
Yes -can confirm part no 90179-18006 is the 12mm size-just measured to check!
« Reply #8 on: 10 February 2016, 07:41:52 pm »
Just discovered that I have both:
The Kit 90891-10124 with the 12mm Nut and washer in it and the Kit 90891-10124 with two separate packages in it.
The part numbers packaged in two separate packages within the package are:
90215-21290 Washer
90179-18006 12mm nut
See pics, both are 12mm and the only difference in the two is that the individually packaged nut in the package is shiny  :eek
