Date: 23-03-26  Time: 07:53 am
Author Topic: How can I find something like this?!!!  (Read 1590 times)
kukiz1984
« on: 25 January 2016, 06:43:34 pm »
Hi
I have installed givi stoplight in my e52 top box but for some reason it has stopped working after a few months. I removed those lights today a saw that 6 bulb circuit is damaged. Does anyone know If I can replace these without buying a whole thing?
thx a lot.
pilninggas
Re: How can I find something like this?!!!
« Reply #1 on: 25 January 2016, 07:08:16 pm »
It's a bit hard to tell, but it doesn't even look soldered. Soldering all those components to the copper tracks will surely help.
characticus
« Reply #2 on: 25 January 2016, 07:31:50 pm »
Should be easy enough to solder in replacement bulbs. I assume remaining four are working ok?
kukiz1984
« Reply #3 on: 25 January 2016, 07:35:09 pm »
That's the thing the whole circuit doesn't work anymore, I was trying to find replacement bulbs on the internet but no luck.
NorthWestern
« Reply #4 on: 25 January 2016, 07:48:06 pm »
You could find the fault by going round the bulb pins with a small battery, like a AA one or similar.  The circuit should provide power to all bulbs at once so moving where you put the pos/neg power should show where a break is.  Try cpc Farnell for bulbs
chaz
« Reply #5 on: 25 January 2016, 07:57:52 pm »
search 12v capless bulbs on ebay, look on the bulb to see watts, if non of the other bulbs are working they have either blown or theres a break in the pcb circuit, you could mend it with solder when you solder the new bulbs in.
kukiz1984
« Reply #6 on: 25 January 2016, 08:14:22 pm »
Thx a lot for all your replies guys.
Will try to get some new bulbs and solder it back together
pilninggas
« Reply #7 on: 25 January 2016, 10:10:28 pm »
or replace the bulbs with 12v leds - loads on the bay in all colours.
