Date: 14-05-26  Time: 20:51 pm
Author Topic: Drilling exup bolt  (Read 4535 times)
teecee90
Drilling exup bolt
« on: 17 January 2016, 09:01:06 pm »
Any tips for drilling out and re-tapping a snapped exup bolt? I'm fairly competent with the spanners but have never tackled anything like this.
Cheers
b1k3rdude
Re: Drilling exup bolt
« Reply #1 on: 17 January 2016, 09:15:03 pm »
Remove the headers and take them to a local engineering shop and let them drill it out via an over-head drill.
Why? because the hole said bolt screw into is hardened and to successfully drill out the snapped bolt you have to drill precisely in the middle of said bolt. If your off-center even a little, as you go up in drill bit sizes you will eventually get the point where the edge of the drill bit will meet the threaded edge of the 6mm hole in the headers. A) you will possibly damage said thread and B) there will still be too much of the old stud left to realistically remove it and C) if you fuck it up you wont be able to put a timesert or helecoil in due to the hardened metal etc.
Do it right, do it once and when your done replace those 3x m6*10mm bolts with titanium replacements -
- http://www.ebay.co.uk/itm/Ti-Titanium-M6-x-10mm-TAPER-HEAD-Socket-Cap-Screw-Bolt-Allen-Key-Silver-/291049602623
nickodemon
« Reply #2 on: 17 January 2016, 09:28:07 pm »
I had a snapped exup bolt on one of my fazers and i used a set of strong mole grips on the bit of the bolt sticking out (if you have any of the bolt sticking out!)and it freed off and i eventually got it out.. Worth a try before sending off to be drilled out. B1k3rdude is bang on tho about not foccing it up by drilling yourself. ;)
sadlonelygit
« Reply #3 on: 18 January 2016, 11:54:45 am »
i did it in situ, but i am an engineering god :rollin
centre punch, a new good drill bit and a nice slow speed, or take it all off and get it done properly
b1k3rdude
« Reply #4 on: 18 January 2016, 12:03:05 pm »
For that to work the OP would have to be dead center, not snap the drill bit/s off in the stud....
mark g
« Reply #5 on: 18 January 2016, 08:34:54 pm »
Yep let the pro's sort it out, mine was done recently by a mate who runs a workshop.
greg1953
« Reply #6 on: 18 January 2016, 09:04:30 pm »
I may have posted about this previously but I had three snap off, took the headers to Armstrongs ( ARD )at Newcastle, £20 per bolt, superb job....theres sure to be somewhere similar near to you, don't try it yourself.
Greg
teecee90
« Reply #7 on: 18 January 2016, 10:24:54 pm »
That's a pretty clear consensus.... off to the machine shop it is then. Thanks all.
b1k3rdude
« Reply #8 on: 18 January 2016, 11:53:20 pm »
Dont forget to replace the bolts after its done  ;)
