Date: 07-05-26  Time: 18:17 pm
Author Topic: after some help please  (Read 3048 times)
wesfazer
« on: 16 January 2016, 11:19:36 pm »
hi guys im new to site and after some help please i have a 2001 fazer 600cc fzs  with abit of play in the rear on bottom of the shock when on centre stand when i pull up on the back wheel (linkage pivot wear can i buys parts bearing and bushs ti fix it cheap not yamaha prices brought 2 nd hand one on ebay but it worse than mine once fitted
wesfazer
Re: after some help please
« Reply #1 on: 16 January 2016, 11:22:50 pm »
plus how do i make my head lights better for night time riding
Val
« Reply #2 on: 17 January 2016, 01:23:47 am »
Hello there and welcome  :)
Deefer666 is your answer for spare parts: http://foc-u.co.uk/index.php/topic,19135.msg221631.html#msg221631
For the headlights you can do this mod: http://foc-u.co.uk/index.php/topic,181.0.html
Or just get HID and do the conversion yourself - some reflectors cutting  involved
or use the Fazer kit from these guys:
https://www.retrofitlab.com/en/yamaha-fzs600-mh1-1.html
andybesy
« Reply #3 on: 17 January 2016, 07:51:15 am »
Anyone know, How much play is normal in shock linkage?
« Reply #4 on: 17 January 2016, 08:11:23 am »
zero play
This is the place to get what you require and good to deal with  http://shop.marksman-ind.com/
wesfazer
« Reply #5 on: 17 January 2016, 11:36:34 am »
 BKM2035JUU bearing Needle Roller Bearing  koyo
BHKM1730JU Bearing needle roller Bearing koyo
IKO G TA172OZ
Jules-C
« Reply #6 on: 17 January 2016, 01:06:11 pm »
You will usually get 1mm or so of movement if you put the bike on centre stand and try lifting the back wheel.  You'll find the same on new bikes in the showroom.  Anything substantially more than that is a problem.
limax2
« Reply #7 on: 18 January 2016, 03:41:53 pm »
 :agree  Jules-c.
 At the last m.o.t. the guy put a long bar under the wheel to test for play and said there was a bit of play, but then said don't worry they are like that from new.
« Reply #8 on: 18 January 2016, 04:11:17 pm »
Many 1000 have about 1mm of play, but the 600 doesn't normally have any play. I just checked my own 600 which I changed the bearing and bushes on 22000 miles back,and it has zero play. Any play in the 600 is an indication of wear. However 1mm of play at the wheel in not a lot as the distance from the bearing is over the 500mm exaggerating the play.
