Date: 08-05-26  Time: 00:25 am
Author Topic: Front brake not activating rear brake light  (Read 5662 times)
slinky2000
« on: 11 January 2016, 10:43:04 am »
Is this a common problem? This si my first bike so I'm not 100% sure, but on my pre ride checks I noticed my front brake lever wasn't activating the brake light.  Would this be the microswitch on the lever or something else?
It's a 2000 fzs600 boxeye.
Anyone know where the best place to get a replacement online?
bandit
Re: Front brake not activating rear brake light
« Reply #1 on: 11 January 2016, 11:47:49 am »
You should hear it click when you pull the lever in if it don't it's probably broke.
Put FZS600 Front brake switch into Ebay. :)
Deefer666
« Reply #2 on: 11 January 2016, 12:38:27 pm »
There's a micro switch under the front brake lever, sometimes these break and sometimes the wires get pulled off.
« Reply #3 on: 11 January 2016, 02:05:44 pm »
As Deefer says, I've had the wires to the switch break and the switch itself fail.
If it's the switch, you may be able to get it working again by dismantling and cleaning, but it's a fiddly job.
Don't be tempted to buy one of the cheap aftermarket replacements available on ebay, they corrode like mad and the internal spring
is too weak... a used genuine one is better value if you don't want to pay Yamaha's price for a new one.
Jules-C
« Reply #4 on: 11 January 2016, 02:12:00 pm »
I've had to replace my switch a couple of times but genuine Yamaha ones aren't expensive.  The last replacement was several years ago so Yamaha may have improved the quality of them.
I assume the brake light is working when the rear brake is applied ruling out blown bulbs?
BBROWN1664
« Reply #5 on: 11 January 2016, 03:07:30 pm »
Sometimes the plunger just gets stuck in (as held in when brake lever released) so a squirt of WD40 and a bit of prodding will fix that.
Alternatively the plunger may have been broken or the wires to the switch have been broken.
slinky2000
« Reply #6 on: 11 January 2016, 04:46:49 pm »
cheers guys.  It's still clicking and wires look intact, but no light on.
Yes the light comes on with the rear brake applied so it's not the bulb.
I'll check the wires properly when I get home from work and try and clean the contacts etc and see what happens.  if not I'll source a new switch somewhere.  Anywhere online I can get a genuine Yamaha one?
bandit
« Reply #7 on: 11 January 2016, 05:10:31 pm »
AJ SUTTON, put in model & year,you will find it in braking under front Master cylinder pic. :)
slinky2000
« Reply #8 on: 11 January 2016, 05:14:02 pm »
Nice!!!  That's a cracker website.  I'll be using that in the future!
HarryHornby
« Reply #9 on: 12 January 2016, 01:37:36 pm »
As others have said, fairly standard thing to go wrong, had to change the switch on my old Fazer twice, once because it broke and again because I bought a cheap one off Ebay to replace it and it stopped working the following winter.
slinky2000
« Reply #10 on: 12 January 2016, 02:11:04 pm »
Got it sorted last night, turns out the connections to the switch were corroded and just needed cleaned up.
I order a microswitch anyway just to be safe in the future!
