Date: 01-04-26  Time: 19:42 pm
Author Topic: Bleed Nipples???  (Read 1642 times)
chunk166
Bleed Nipples???
« on: 02 January 2016, 06:03:18 pm »
Happy New Year everyone, Just a quick question.How do I free up the bleed nipples on my rear caliper? They look quite corroded  but I don't want to snap off the bleed nipples as they look a bit dodgy & as my bike is my only transport I need to get it right first time!! I understand that these (fzs600 2002) calipers as notorious for seizing up!! Apart from fitting a FZS1000/XJR1300 caliper (lots of £££££). I expect this should be in the FZS600 section but I feel i might get more tips/answers here in the General section.
[/size]
[/size]Thanks in advance
[/size]
[/size]Ray
joebloggs
Re: Bleed Nipples???
« Reply #1 on: 02 January 2016, 07:50:12 pm »
WD40/plusgas etc etc
If you think its likely to shear you and get banjo bolts with bleed niples in them
chunk166
« Reply #2 on: 02 January 2016, 08:04:35 pm »
Never heard of "banjo bolts with bleed niples in them" I will have a look on ebay & order 1. I suppose they work the same way as normal banjo bolts??
joebloggs
« Reply #3 on: 02 January 2016, 08:07:55 pm »
Yeah, tighten up banjo as normal, then spanner on both banjo and bleed nipple to lock it up
chunk166
« Reply #4 on: 02 January 2016, 08:10:19 pm »
Awesome, thanks for the info. Just 1 thing there are two sizes of "pitch" 1.00 & 1.25 Any idea which is correct??
Thanks ;)
joebloggs
« Reply #5 on: 02 January 2016, 08:52:49 pm »
M10 1.25 pitch
chunk166
« Reply #6 on: 02 January 2016, 08:58:15 pm »
Cheers, Will order one now  :thumbup :woot
Deefer666
« Reply #7 on: 03 January 2016, 10:57:50 am »
I've got some Banjo with bleed nipples, I used them on Laura's trike when I realised that the previous owner had not just snapped the bleed nipples off but filled them in as well  :eek
But I always heat corroded bleed nipples up and then quench them with penetrating oil (not WD40, that's wank!). I do that a couple of times and they nearly always wind straight out.
