Date: 15-03-26  Time: 02:48 am
Author Topic: Fz6 fazer idle  (Read 9725 times)
Dimitar
Fz6 fazer idle
« on: 27 December 2015, 05:13:53 pm »
hello and happy new year, I need help, my fazer 2004 have high idle speed - cold start at 2200, when is hot stay at 1600-1800 rpm, this bring me jump when start first gear, during drive no problems, what is wrong, why keep these rpm, the bolt for regulation no efect, help me
Grahamm
  • Global Moderator
Re: Fz6 fazer idle
« Reply #1 on: 28 December 2015, 12:42:35 am »
There are a series of checks and tests listed in the Haynes Manual, but there's too much to type out.
When did the bike last have a full (24,000 mile) service?
Dimitar
Re: Fz6 fazer idle
« Reply #2 on: 28 December 2015, 08:50:15 am »
hi, haynes manual is for the old model, i have FI system, no carburators, full service check not exist in my country, Yamaha dealer only can assy the mirrors of the new models, I like to repair myself, and to know how to do it, study now all manuals, when I buy, change cables, clutch, tyres, all liquids, brake pads, repair forks, steering berings, filters, oils, only rpm cant fix, looks all is ok, no damages, termostat open in right time, I think the sensors are work, usually sensors work or not, no middle possibility
Grahamm
  • Global Moderator
Re: Fz6 fazer idle
« Reply #3 on: 28 December 2015, 12:20:54 pm »
This is the Haynes Manual for the FZ6.
Here's a photo of the page detailing how to adjust the idle speed:
Dimitar
Re: Fz6 fazer idle
« Reply #4 on: 28 December 2015, 02:03:29 pm »
thanks, will try, i have somekind of vacummeter, today was 16 sunny, drive, already keeping 2000-2200, is needed valve clearance checking? the manual yamaha Fz6 400 pgs, the idle procedure start with valves
Grahamm
  • Global Moderator
Re: Fz6 fazer idle
« Reply #5 on: 28 December 2015, 08:24:18 pm »
I don't know.
Checking the valves is a pretty big job, I'm not that experienced with this, so I'd leave it to someone who knows what they're doing!
Hope you get it sorted.
Re: Fz6 fazer idle
« Reply #6 on: 28 December 2015, 10:07:21 pm »
Synch the throttle bodies and set the TPS as a start point
helmetvonthrob
Re: Fz6 fazer idle
« Reply #7 on: 29 December 2015, 11:51:54 am »
I would check for air leaks (perhaps around the carb rubbers (yes I know you have FI) the ones which are between the throttle bodoes and the head.  Also, there are a load of small diameter pipes in the area so if you've had the tank up and airbox off to fit plugs, maybe you've nipped one.
Has the problem always been or did it start after you did something?
Dimitar
Re: Fz6 fazer idle
« Reply #8 on: 29 December 2015, 02:38:58 pm »
Hi, the sinch didn help, nothing change, also think for small hole somewhere on pipes. when I buy, was like that, 1600-1800 rpm, but was in good shape, no missing units, and is chalenge for me to repair all, my hobby, yeaterday see new situation, when start cold was 1800, shortly go to 1300, after return back to 2000 and keep them all day, so, what is set of TPS?
Re: Fz6 fazer idle
« Reply #9 on: 29 December 2015, 06:53:00 pm »
Is the speedometer the same type as this?
https://i.ytimg.com/vi/iGd0lENpQ3w/maxresdefault.jpg height=225
Dimitar
Re: Fz6 fazer idle
« Reply #10 on: 30 December 2015, 12:26:03 pm »
yes that type, just for checking, if I have bad sinchro, or TPS is bad, how this will reflect to the drive? asking this, because i dont have problems durring driving, reaching 235 kmh
Re: Fz6 fazer idle
« Reply #11 on: 30 December 2015, 12:35:52 pm »
Faulty TPS usually effects the Idle speed.
There was a Yamaha recall on these bike to replace the TPS.
Download the FZ6 manual in the download section
http://foc-u.co.uk/index.php?action=downloads;sa=downfile&id=10
On page 7-7 it explains how to go into diagnostic mode and you can check the operation of the TPS
Diagnostic  Code 1 should show 16
