Date: 30-04-26  Time: 11:35 am
Author Topic: FZS 1000 cutting out issues  (Read 2082 times)
msewelly
« on: 26 December 2015, 10:08:09 pm »
Hi,
Was riding around London, stopped the bike, went to restart it but nothing....all the lights were on, killswitch was off. Trouble is it wouldnt even turn over. In a moment of annoyance I pushed the side stand up hard and that seems to do the trick, I have a feeling its almost certainly the sidestand switch as it cut out when riding. I checked the fuses and all are fine, how do you check the switch, clean etc.
Mant thanks
slappy
Re: FZS 1000 cutting out issues
« Reply #1 on: 27 December 2015, 10:59:46 am »
Clean the switch in situ first, just use loads of wd40 or similiar and then check if it is moving in and out freely and not sticking, they do collect a lot of crud.
nickodemon
« Reply #2 on: 27 December 2015, 11:39:32 am »
To test the sidestand switch you will need to take off the left hand side panel and look for a dark blue plug. Disconnect the plug and test for continuity between the pins with the side stand down. Try it when it's up also. I can't recall off hand which gives continuity, but as long as one gives continuity and the other doesn't then it's working
