Date: 30-04-26  Time: 16:27 pm
Author Topic: AIS and Carb coolant bypass removal kit UK ?  (Read 7418 times)
mark g
« on: 26 December 2015, 11:12:08 am »
Guys, planning to remove the above on my Gen1 whilst it's laid up over the winter, just done the read up on Pats page, I was just wondering if the Ivan's kit he describes are available here on the UK?. If not where would I get all the various blanking plugs etc?.
Thanks in advance guys
Cellarman
Re: AIS and Carb coolant bypass removal kit UK ?
« Reply #1 on: 26 December 2015, 01:52:24 pm »
Doing mine shortly, I got all the parts needed from ebay for about a fiver, just make sure you get a tapered tap
mickvp
  • Global Moderator
« Reply #2 on: 26 December 2015, 02:33:11 pm »
I ordered the hole shot kit from the states (didn't fancy tapping out bits etc) it came in about ten days.
www.holeshot.com
PieEater
« Reply #3 on: 26 December 2015, 03:48:13 pm »
I also used the Holeshot kit and can recommend it as it is a doddle to fit unlike the Ivan's approach of tapping out the spigots which I found to be a right PITA though admittedly I'd never tapped anything before which might explain why I quickly gave up and bought the Holeshot kit. It's just a pain that postage from the US costs about as much as the kit so although IMHO it's the best option it's not a cheap one.
tex
« Reply #4 on: 26 December 2015, 04:00:03 pm »
  +1 on the holeshot
Peasy
« Reply #5 on: 26 December 2015, 07:12:50 pm »
Has anyone got a copy of the instructions for the holeshot kit at all please that I could have a read of? Just want to see how much of a doddle it is.....cheers
Lewis
mickvp
  • Global Moderator
« Reply #6 on: 26 December 2015, 07:22:16 pm »
I don't have the instructions to hand, but it is basically the same instructions as can be found on pats site, only instead of tapping the 4 holes the holes hot kit comes with 4 caps which you loctite over the holes.
http://www.cartestsoftware.com/fz1/airinductionsystemremoval.html
Peasy
« Reply #7 on: 26 December 2015, 07:28:07 pm »
Thanks mate.
mark g
« Reply #8 on: 26 December 2015, 08:28:12 pm »
Cheers guys, just found the Holeshot website, looks like they open back up on the 7th Jan.
Peasy
« Reply #9 on: 26 December 2015, 09:11:37 pm »
Let me know if you're going to order mate, I may order and we may as well only pay one lot of shipping etc.....
PieEater
« Reply #10 on: 26 December 2015, 09:49:51 pm »
Dale recommends using a copper silicone to properly seal the blanking caps on the Holeshot kit - I bought this from Amazon - http://www.amazon.co.uk/V-tech-Copper-Silicone-Instant-Gasket/dp/B00442ONX0 - and it worked well.
« Reply #11 on: 28 December 2015, 05:50:55 pm »
I went the holeshot option also, be aware these are an interference fit, make sure you fit them in exactly in line with the spigots as the start before tapping them in.
I also used the copper silicone.
You will need to take the rad off to make fitting easier.
PieEater
« Reply #12 on: 29 December 2015, 06:29:24 am »
I don't recognise your description from my experience of the Holeshot kit. The caps that I received were held in place by grub screws and slipped over the spigots with no force required. From what I can see this is still the case, maybe you got some of the caps that Justy (I think)  made a while back ??
You can see the grub screws in the picture of the fitted kit on  the Holeshot product page.
http://www.holeshot.com/main/showimage.php?/imgsrv/w_640/fz1/fz1_ais_cap.jpg
Hedgetrimmer
« Reply #13 on: 29 December 2015, 08:06:57 am »
Same here, want to get this done too.
« Reply #14 on: 29 December 2015, 08:15:09 am »
took mine off earlier this year.another foccer cut down the origanal ais and sealed them.i found some blanking plugs locally,been fine and cheap and now have excellent access to spark plugs .
mark g
« Reply #15 on: 29 December 2015, 01:19:04 pm »
Nice work Red :-)
