Date: 20-04-26  Time: 06:10 am
Author Topic: pc help  (Read 2715 times)
devilsyam
pc help
« on: 12 December 2015, 04:20:48 pm »
I have an old am pc running xp in its day was cutting edge recently been going into long winded disc checks that go no ware so restart abort the disc check and works fine
I only use it for Web pages as runs front page
Any clues
Re: pc help
« Reply #1 on: 12 December 2015, 04:40:34 pm »
Try downloading and running ADWCLEANER, you'd be amazed how much shit that can find and get rid of, speeding things up in the process.
I wouldn't expect miracles though, it's simply an old system that you're using.
devilsyam
Re: pc help
« Reply #2 on: 12 December 2015, 05:31:29 pm »
Ok further up date
C drive is my normal drive and I have two dump drives e and f and seems e has gone down
Therefore I think the pc in checking hardware can't get passed this drive
How do I stop it looking for the e drive
NorthWestern
Re: pc help
« Reply #3 on: 12 December 2015, 06:11:38 pm »
Apart from just unplugging it you will be able to disable it in the bios settings.   When the pc boots up watch the screen, it will say something like "press f8 to enter bios" .  Watch what you do in there as you can change many of the timers etc it should be self explanatory to get to the e drive and disable it, then save and exit
NorthWestern
Re: pc help
« Reply #4 on: 12 December 2015, 06:12:26 pm »
You must press the bios setup key while the message is on screen, might take a couple or reboots to catch it
Re: pc help
« Reply #5 on: 12 December 2015, 06:29:50 pm »
Just been through the process of buying another computer -- its all here http://foc-u.co.uk/index.php/topic,18662.0.html
I went for a refurb one for £130 ish Having used the new one now for a few weeks it is so much faster than my old xp one, that just like you I doggedly held on to, and so far my old programs still work on it as it is a win 7 pc
Re: pc help
« Reply #6 on: 12 December 2015, 07:00:33 pm »
May as well apply for the Windows 10 upgrade while it's still free.
Once you customise it to suit whatever you want it's pretty much the same as Windows 7 anyway, with a little bit of Windows 8 chucked in for good measure.
I quite like it now, and have stayed with using Google Chrome because it works with Adblock and Whatsapp Web which i use a lot but Microsoft Edge doesn't allow, which is pretty shit to be honest.
Re: pc help
« Reply #7 on: 12 December 2015, 07:03:06 pm »
Ok further up date
https://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/rsm_enable_drive.mspx?mfr=true
devilsyam
Re: pc help
« Reply #8 on: 12 December 2015, 07:07:14 pm »
Can't tun windows front page on anything but xp hence I've hung on to it I have 10 on the laptops
Re: pc help
« Reply #9 on: 12 December 2015, 07:11:15 pm »
Sorry devilsyam, that was directed more at Fazersharp.  :)
Re: pc help
« Reply #10 on: 12 December 2015, 07:25:04 pm »
Sorry to confuse things
Sorry to confuse things -- I have a few programs that I know will not work on 8 or 10, and the mrs uses 7 at work and wants it the same here
BBROWN1664
Re: pc help
« Reply #11 on: 12 December 2015, 08:40:38 pm »
I run front page 2007 on windows 10
PieEater
Re: pc help
« Reply #12 on: 13 December 2015, 11:10:33 am »
To stop Windows XP from automatically checking for disk errors on your E:\ drive;
Obtain a command box by clicking Start > Run
type the following command and hit Enter chkntfs /x e:
Then reboot to see if the symptom has cleared - but bare in mind you evidently have an issue with this disk and it shouldn't be used.
See here for more detail - https://support.microsoft.com/en-us/kb/160963
anutz
Re: pc help
« Reply #13 on: 13 December 2015, 03:25:17 pm »
As PieEater says, most likely HDD phyiscal issue, get your data backed up regardless of the HDD status.
SMART tools offer some indication of impending failure, if you can find some that will install on windows XP
