Date: 20-04-26  Time: 06:06 am
Author Topic: Anybody fitted SRAD forks to a 600 Fazer?  (Read 1577 times)
joebloggs
« on: 10 December 2015, 06:15:10 am »
Or more to the point can the stem's be swapped?
I know every man and his dog uses R1 forks but got these cheap
Answers on a postcard please :D
Deefer666
Re: Anybody fitted SRAD forks to a 600 Fazer?
« Reply #1 on: 10 December 2015, 05:00:11 pm »
The stems will need to be swapped... Local engineer job. I doubt the average person will be able to do it. You may need spacers as well. I only used an R1 on my FZS because as you said I got them cheap but even they are not a straight swap and require the stems swapping and a spacer under the top yoke.
Punkstig
« Reply #2 on: 10 December 2015, 10:39:23 pm »
If you go through with it make sure you fit the srad600's 4 pot calipers not the 750's 6 pots as they are shocking!
joebloggs
« Reply #3 on: 14 December 2015, 03:22:30 pm »
Found a set of four pots and a pair of Ferodo disc's for just over £90. Need to find someone to press out/in the steering stems now
joebloggs
« Reply #4 on: 14 December 2015, 03:48:52 pm »
After a SRAD USD lower yoke if anyone has one kicking around
