Date: 25-04-26  Time: 13:46 pm
Author Topic: rear caliper R clips  (Read 1806 times)
Paulfzs
« on: 07 December 2015, 06:47:30 pm »
doing brake pad change today and noticed 3 R clips missing  :eek :eek :eek  luckily the spring plate put enough tension on the retaining pins to keep them in...
Any idea where i can get them from? or the size so i can order some from the bay?
Id like to avoid taking caliper off to measure so if anyone knows itd help.
RMT1983
Re: rear caliper R clips
« Reply #1 on: 07 December 2015, 06:56:59 pm »
http://www.ebay.co.uk/itm/Yamaha-FZS-600-Fazer-5DM7-2000-Front-Brake-pad-pin-/291563976900?hash=item43e29138c4:g:CwAAAOSwWKtUyjQI
If it was me mate id be tempted to go for stainless bits..................................
limax2
« Reply #2 on: 07 December 2015, 08:14:28 pm »
Assuming this is a FZS1000 rear calliper the pin is 6mm dia and the wire size of the R clip is 1.25mm dia.
Clip same as used on the front of the FZS600. Yamaha Pt. No. 3GM25925-00
You could always use some locking wire as a temperery fix.
