Date: 25-05-26  Time: 08:36 am
Author Topic: Chatter noise when i pull the clutch in..  (Read 8916 times)
scifilord
« on: 26 February 2012, 10:02:22 pm »
HI, i have just got a fzs 1000 and need some help. When i am slowing down and i pull the cluch lever in i get a noise for about 2 - 3 seconds it sounds like a cam chain chatter or a ticking noise any ideas thanks.....
eddie
Re: Chatter noise when i pull the clutch in..
« Reply #1 on: 26 February 2012, 10:23:44 pm »
they all do that sir !!!
scifilord
« Reply #2 on: 26 February 2012, 10:45:45 pm »
Thanks, any idea what causes it?
Falcon 269
« Reply #3 on: 27 February 2012, 04:14:24 am »
They all make clutch noise in neutral with clutch lever out, but what you describe is different.
Sounds like it might be chain/front sprocket noise.
Can you be more specific on location of the noise?
scifilord
« Reply #4 on: 27 February 2012, 11:40:14 am »
Hi Falcon, the noise sounds like its coming from the front of the engine right hand side.
I don't have any unusual noises coming from the bike when its idling i only get this noise when im slowing down and i pull the clutch lever in.
Falcon 269
« Reply #5 on: 27 February 2012, 02:14:56 pm »
Strange one, this.
Don't think it's cam chain.  Can't think of anything front right inside the engine that would make an intermittent noise either.
I'd start by ensuring that the exhaust headers are secure and that you don't have any stones or such caught that might rattle under specific conditions.  Check the rear header mount bracket, too ... the weld on that can fail and you could be hearing a reflected noise.  Look on the rear of the EXUP housing close by the centrestand pivot.
Definitely check that the EXUP is working correctly and the cables properly adjusted.  Worn/maladjusted EXUPs can cause all sorts of weird noises. :)
I'm assuming clutch and gearbox works as it should?
scifilord
« Reply #6 on: 27 February 2012, 03:48:59 pm »
Thanks falcon, will go through the things you have listed.
I had a problem with the gear selection when the bike got warm really difficult to change gear and find neutral. Searched the forum and it did seem to be the plug problem was going to be the cause but when i had a look the plug is in place.
I did find the wear marks on the clutch basket and clutch inner that have been mentioned and i filed them down and the gear selection is a lot better now.
Falcon 269
« Reply #7 on: 27 February 2012, 05:18:41 pm »
How much did you have to file down to remove the wear notches ... ? ;)
scifilord
« Reply #8 on: 27 February 2012, 05:59:42 pm »
Hi it wasn't much to be honest. If you ran your finger over them you could just feel them. Mileage is 16,000, thing is the noise was there before but i do think it has gotten louder since i filed the notches down.
scifilord
« Reply #9 on: 29 February 2012, 06:58:09 pm »
Today i was running the bike on it's center stand i was taking it up to 40 mph then pulling the clutch lever in and letting it slow down in a hope to pinpoint the noise.
It's a difficult noise to pinpoint but it did seen to be coming from the downpipes could it be the exup valve?
It almost sounds like there is something in one of the downpipes rattiling about......
gel
« Reply #10 on: 29 February 2012, 08:55:29 pm »
I had a rattle simlar to yours that I could not pinpoint and thought it was a clutch issue, turned out to be an exup valve that had worn on the pully end, and it was rattling against the bush. Even though I had serviced every 4K since 15K its now done 60K  >: . So get your ear down by the valve on both sides. New (OK used) but good condition exup valve and new bushes, humms like a baby and no rattle.
scifilord
« Reply #11 on: 29 February 2012, 09:22:00 pm »
Thanks gel, I'm going to strip the exup valve down in the next few days and service it to see if that helps.
Can i run the bike with the exup valve out to see if the noise disappears or will i damage something Thanks...
ghostbiker
« Reply #12 on: 29 February 2012, 09:27:02 pm »
you can run it with it out, it will be louder though.
If you service it and coppaslip it up you may find it will be less rattle noise. at least untill the coppa slip burns off.
mine rattles a tiny bit, actualy all this talk of exups lately i think i will give mine a service agin lol
scifilord
« Reply #13 on: 29 February 2012, 09:38:13 pm »
thanks, think i will give it a run with it out if the noise disappears i will be happy because at the moment I'm thinks it could be something more serious like a gearbox or camchain issue....
nickodemon
« Reply #14 on: 01 March 2012, 05:20:05 pm »
I had chattering noise a while ago. It turned out to be the the exup valve. The cables had too much free play. Adjusted them and the noise disappeared.  :)  Good luck!
