Date: 23-04-26  Time: 14:21 pm
Author Topic: Master cylinder screws.  (Read 4952 times)
CaptainCazador
« on: 17 November 2015, 09:44:08 pm »
I know master cylinder screws like to round off so this time around I wish to have replacements to hand rather than fighting to get minced ones back in until I can obtain replacements.
I have never bled the Fazers brakes but from looking at the screws I think they are M4 X 20mm can anyone confirm this before I place my order?
Thanks.
Jamieg285
Re: Master cylinder screws.
« Reply #2 on: 18 November 2015, 01:41:56 pm »
I can't confirm the size, but would agree with your guess.
I took my originals into the local bolt suppliers and they were able to match them easily, so they aren't anything odd.  I switched to ones that need an allen key rather than screw driver, less likely to get chewed up.
joebloggs
« Reply #3 on: 18 November 2015, 01:51:21 pm »
+1 on the allen key, stainless with a little copperslip will make sure they come out next time
Paulfzs
« Reply #4 on: 18 November 2015, 01:53:18 pm »
just weld it on  :rollin :rollin :rollin :rollin :rollin :rollin
joebloggs
« Reply #5 on: 18 November 2015, 03:13:55 pm »
[/quote
Thats a silly idea, 6 inch nails punched through the bottom and bent over over is an option
Paulfzs
« Reply #6 on: 18 November 2015, 05:04:46 pm »
[/quote
Not to dig at him too much, but this is his handy work on an old sprocket :D
« Reply #7 on: 18 November 2015, 05:16:16 pm »
I take it nobody bothered opening the 2nd link I posted above, the one with the same part number as in the 1st link, and the size?
I'm wasted on here.  :'(
Paulfzs
« Reply #8 on: 18 November 2015, 08:02:27 pm »
i see no link, only code that links to a different dimension  :D :D
« Reply #9 on: 19 November 2015, 06:51:28 am »
You been watching Quantum Leap perchance?  :lol
StuSid
« Reply #10 on: 22 November 2015, 11:18:49 am »
I bought these for mine as the previous owner had wrecked one of the screws took me ages to get it out.
http://www.ebay.co.uk/itm/151432270518?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Deefer666
« Reply #11 on: 22 November 2015, 03:02:16 pm »
If you get some "Go Through" screwdrivers and tap the top of the screw driver with a nylon mallet it shocks the corrosion holding the screw in, it also seats the screwdriver tip into the recess more and 9 times out of 10 the screw will come undone.
It also helps to know the difference between a Pozi-drive screw and a Phillips screw and use the appropriate screwdriver so you don't mash up the recess in the first place.
Flak
« Reply #12 on: 22 November 2015, 07:52:36 pm »
They're probably neither of those but JIS.
Deefer666
« Reply #13 on: 23 November 2015, 07:03:20 am »
JIS = Standard Philips head screws, the problem arises when people do not know the difference and use a Pozi-Drive screwdriver in them. Which will of course chew the recess up.
