Date: 17-04-26  Time: 11:43 am
Author Topic: Parts compatability with 600  (Read 16695 times)
bolanjames
« on: 14 November 2015, 04:05:59 pm »
Hi everyone. Could someone let me know if the fuel tanks are the same on both bikes. Are they interchangable and also the body work plastics. Thanks.
RMT1983
Re: Parts compatability with 600
« Reply #1 on: 14 November 2015, 09:11:55 pm »
yes they are. the only different I found was that the rear seat fairing for the 600 has holes for the pillion grab handles and the 400 doesnt
bolanjames
« Reply #2 on: 15 November 2015, 10:20:33 am »
Thanks for that. Should have asked this as well but are the clocks a straight swap with the 600 to give mph reading or is there some other stuff to do as well.
His Dudeness
« Reply #3 on: 15 November 2015, 11:01:23 am »
The tanks may be the same but the 400 has a vacuum tap under the tank whereas I think the 600 has an off on fuel tap. I think it should still work but you might want to swap over the vacuum tap. I could be wrong though I haven't seen a 600 tank. The clocks I'm not sure about but I'd be surprised if it was a straight swap
Deefer666
« Reply #4 on: 16 November 2015, 07:45:53 pm »
I thought most parts, apart from the obvious where the same. I have dropped an entire 600 clutch basket into a 400 and it fitted. The 400 clutch is pathetic!
