Date: 20-04-26  Time: 12:49 pm
Author Topic: Anyone fitted stainless studs to rear wheel adjusters?  (Read 4367 times)
joebloggs
« on: 03 November 2015, 04:18:43 pm »
As it says?
slappy
Re: Anyone fitted stainless studs to rear wheel adjusters?
« Reply #1 on: 03 November 2015, 04:50:27 pm »
I haven't but I considered fitting some but  think they might be too brittle.
joebloggs
« Reply #2 on: 03 November 2015, 05:03:32 pm »
Considering people use stainless for brake calipers I don't see strength being the issue
slappy
« Reply #3 on: 03 November 2015, 07:34:18 pm »
I know people use them for brake calipers but again I have always thought stainless steel is more brittle than the low carbon or mild steel used normally in these situations.
But I will admit that I could be totally wrong :)
NorthWestern
« Reply #4 on: 03 November 2015, 07:41:13 pm »
Yep. They are fine and less of stain!
joebloggs
« Reply #5 on: 07 November 2015, 09:01:08 pm »
Word of warning
We had a good look at removing the studs today and several engineers from work think that maybe they're not removable and that Yamaha cast the stud into the adjuster block. Guess you could drill and tap it if it did shear but I left it alone as it seemed more trouble than it was worth
NorthWestern
« Reply #6 on: 07 November 2015, 09:26:24 pm »
The chain as adjuster studs? They just come right out, nothing special about them.
joebloggs
« Reply #7 on: 07 November 2015, 09:36:43 pm »
I stand correct then, we were worried about destroying the blocks trying to remove them, may have to pay another visit to the engineering dept at work
NorthWestern
« Reply #8 on: 08 November 2015, 12:59:10 pm »
Great timing! Was up at my dads this morning, he is making a motogp style swingarm for my bro's race bike.
Here is the rear end of a standardf YZF750 swingarm cut out, you can see what it looks like on the inside, the adjusters are just bolts through a taped hole.
This is what it is going in!
Hand formed outer plate for the chain side of the new arm.  The sniney tube is the frame end spindle.
sinto
« Reply #9 on: 08 November 2015, 01:20:48 pm »
Still looks a bit fiddly to remove :(
I've never seen any in a bad way so why change them?
joebloggs
« Reply #10 on: 08 November 2015, 02:11:49 pm »
I see that but have you changed the adjuster bolts on a FZS600, only asking as I need to know they can be removed before destroying them trying to get them out
Wheels polished and repainted, swingarm polished, rear plates on swingarm that studs go through painted etc etc, seems a shame not to replace them.
sinto
« Reply #11 on: 08 November 2015, 02:14:21 pm »
Ahh right, you just want it all shiney :)
joebloggs
« Reply #12 on: 08 November 2015, 02:15:56 pm »
Why not
sinto
« Reply #13 on: 08 November 2015, 02:20:15 pm »
Why not
I'm with you, if it can be done,why not do it :)
I just thought earlier you were just changing them for the sake of it :eek
NorthWestern
« Reply #14 on: 08 November 2015, 04:38:17 pm »
Ahh, yeah the 600 uses caps doesn't it. I assumed we were talking 1000 :/
sinto
« Reply #15 on: 08 November 2015, 04:39:52 pm »
Yes it's a different set up, the bolts go into the bracket that holds the rear axle bolt.
joebloggs
« Reply #16 on: 08 November 2015, 06:31:33 pm »
So I'm still none the wiser  :wall :wall :wall
Anyone know if they can be changed on the FZS600
sinto
« Reply #17 on: 08 November 2015, 06:40:45 pm »
Back to the drawing board joebloggs :b
https://www.yamahamotorcyclespares.co.uk/genuineparts/9654/31/yamaha%20fzs%20600%20fazer/rear%20wheel?uID=0
Item 17 clearly shows its attached so you might not be able to remove it without foccin it up :b
Edit....
Could you not take out the units, give them a  clean and paint them with hamnerite or similar? They'll come up a treat I think then just put on shiney new nuts?
joebloggs
« Reply #18 on: 08 November 2015, 07:07:41 pm »
Yeah I know, may even be able to have the threads replaited and mask the rest of it, don't understand why they would go to the trouble of casting it into the block (if thats what they've done) Could do with a sacrificial adjuster block to test
sinto
« Reply #19 on: 08 November 2015, 07:09:51 pm »
There not the most saleable part so you might find a breaker on ebay or somewhere willing to part with one for a cheap price :)
