Date: 20-04-26  Time: 09:44 am
Author Topic: R6 shock settings fzs600  (Read 1270 times)
Nebuchernezzer
« on: 25 October 2015, 07:34:35 am »
I have an r6 shock for my fzs, bought a heavier imperial spring, made a spacer to fit it to the shock. Now I've come to set the damping before I fit the shock and I've not found any useful settings. I've seen the settings for the large gold nut described as clicks on one post, but mine doesn't click. Should it be turns instead? My other two adjustments click.
Apart from that what setting do people use? I'm using debrix front end, wt 0.85kg straight rate front springs. Almost always ride single and weigh just over 70kg, I guess  maybe 80kg geared up?
Any suggestions for settings etc?
Thanks
devilsyam
Re: R6 shock settings fzs600
« Reply #1 on: 25 October 2015, 07:41:55 am »
Pm kebab 19 he's the one for this conversion
