Date:
23-04-26
Time:
11:01 am
Home
Media
old - Fazer Owners Club - old
Fazer 1000/FZ1 corner
New gen 1 has 7000rpm fault code.........................
« previous
next »
Print
Pages: [
Author
Topic: New gen 1 has 7000rpm fault code......................... (Read 4381 times)
nickodemon
GP Hero
on:
22 October 2015, 11:44:34 pm »
I got the new bike yesterday and the tacho was showing the 7000 exup fault... I stripped and cleaned the valve and then lubed with ceramic grease, it feels like it rotates absolutely fine. I then started the bike and it is again showing the 7000 rpm exup valve fault....
Logged
Tmation
Naughty Corner
GP Hero
Re: New gen 1 has 7000rpm fault code.........................
Reply #1 on:
23 October 2015, 08:32:20 am »
Knackered servo or cables then. disconnect cables and see if it goes away
Logged
Naughty Corner
GP Hero
Reply #2 on:
23 October 2015, 09:32:58 am »
Either the EXUP motor gone or stiff cables.
Check the cable are free running and there is slack at the valve first. (Wemoto do a set of cables for £50)
If cables are fine change the Exup motor
Logged
Red Ceri
Naughty Corner
Club Racer
Reply #3 on:
23 October 2015, 12:16:18 pm »
If your cables need adjusting and all you did was clean and grease the valve and put the cables back where they were without re-setting them you would still get the 7k fault code,
adjust the cables as per Pat's page here -
http://www.cartestsoftware.com/fz1/exupmaintenance.html
Then re-check for fault code.
Logged
nickodemon
GP Hero
Reply #4 on:
23 October 2015, 01:58:28 pm »
I noticed that it returns to the closed position slowly, so i will take a look at the cables
Logged
nickodemon
GP Hero
Reply #5 on:
23 October 2015, 05:07:24 pm »
Cables were slack, so adjusted and all seems well
Took it for a spin and motor feels good
Looked at fork seal and it's leaking
Bugger. need to order seals, so is the front end definitely 5pw r1 (2002 - 2003)
Logged
Exupnut
GP Hero
Reply #6 on:
23 October 2015, 08:30:28 pm »
Good to hear :-)........gonna do mine tomorrow.....minus the Tyskie....and the heat lol
Logged
Naughty Corner
GP Hero
Reply #7 on:
23 October 2015, 08:33:59 pm »
Never heard of the 7000K fault code from slack cables
Logged
nickodemon
GP Hero
Reply #8 on:
23 October 2015, 10:46:18 pm »
They were also routed wrong and the valve was positioned slightly out. I will check again tomorrow, as it seems to do it if the bike has been lying a while as it stops doing it when the bike has warmed up
Logged
sadlonelygit
Naughty Corner
GP Hero
Reply #9 on:
24 October 2015, 01:51:54 pm »
4xv-5jj 41mm
5pw 43mm
iirc
get the very nears out!
Logged
nickodemon
GP Hero
Reply #10 on:
24 October 2015, 04:53:16 pm »
Just taken the bike for a 30 mile ride in the wet. It doesn't like white lines! It also doesn't seem to want to lean over as much as the standard fazer? I thought it would because of the r1 front and r6 rear. It definitely doesnt handle anything like my fazer with the 2008 r1 front/r6 shock. I think the chain is too tight so going to loosen it off a bit and see if that has affected the handling. Fork seal has stopped leaking. Just bought a set of seals as well
Logged
nickodemon
GP Hero
Reply #11 on:
24 October 2015, 06:24:08 pm »
Quote from: sadlonelygit on 24 October 2015, 01:51:54 pm
4xv-5jj 41mm
5pw 43mm
iirc
They are 43mm
I now have a set of fork seals that will sit on the shelf until such time as i need them
I have been out again and the fork is still not leaking, so i think either i have been spraying wd 40 or gel cleaner and it has got on the stanchion
Logged
Print
Pages: [
« previous
next »
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
