Date: 12-05-26  Time: 17:26 pm
Author Topic: Parts needed  (Read 4803 times)
zer0n
Parts needed
« on: 19 October 2015, 06:22:53 pm »
Hi,
Looking for some replacement parts for a FZS600 2000.
  • Rocker cover + Bolts & Seal. ORDERED
  • Left Hand Crankcase cover ORDERED.
  • Handlebars (Open to design - OEM, aftermarket, no preference really) ORDERED
Any help would be appreciated.
Cheers
z
RMT1983
Re: Parts needed
« Reply #1 on: 19 October 2015, 07:43:08 pm »
PM me mate
Bretty
Re: Parts needed
« Reply #2 on: 19 October 2015, 11:30:31 pm »
I'm in Northwest London. I have a rocker cover, no bolts or seals. I'm not sure about end plates, or gasket.
zer0n
Re: Parts needed
« Reply #3 on: 19 October 2015, 11:46:12 pm »
Hi there,
Thanks for the reply but I need the bolts and seal as well. Replacing these separately will cost twice as much as the cover from what I've seen.
Bretty
Re: Parts needed
« Reply #4 on: 20 October 2015, 12:41:17 pm »
Tell a lie...  :rolleyes What you see is what you get. Take it or leave it. :D
Bretty
Re: Parts needed
« Reply #5 on: 20 October 2015, 12:42:03 pm »
Picture 2
zer0n
Re: Parts needed
« Reply #6 on: 20 October 2015, 01:44:38 pm »
Hey Bretty,
That's good. Has the seal and caps. If I could source some cheap bolts (can probably salvage 3 or 4) then I'd take it but atm all I have found are a pack for £60. ;[
Will continue searching and let you know.
Cheers
z
Bretty
Re: Parts needed
« Reply #7 on: 20 October 2015, 01:57:26 pm »
You might have a bit more luck in your search if you look for 'cam' cover rather than 'rocker'.  ;)
slappy
Re: Parts needed
« Reply #8 on: 20 October 2015, 02:07:24 pm »
Take one of the bolts to a local engineering supplier or nut and bolt supplier, you might be able to get a matching bolt and if it is like my local supplier they will happily just sell you the amount you actually need.
zer0n
Re: Parts needed
« Reply #9 on: 20 October 2015, 05:39:59 pm »
Thanks for the hints peeps. Will try that tomoz
zer0n
Re: Parts needed
« Reply #10 on: 22 October 2015, 12:40:29 am »
All sorted, I hope.
Cheers peeps x
