Date: 08-05-26  Time: 18:38 pm
Author Topic: core plugs  (Read 4401 times)
midden
core plugs
« on: 15 September 2015, 11:10:57 pm »
Does the cylinder block have core plugs fitted on the side between the fins?
joebloggs
Re: core plugs
« Reply #1 on: 15 September 2015, 11:28:34 pm »
Yeah, you can order some new ones at ibelieveinfairys.com
midden
Re: core plugs
« Reply #2 on: 15 September 2015, 11:54:06 pm »
Sure that's not whataknob.com
joebloggs
Re: core plugs
« Reply #3 on: 16 September 2015, 12:10:30 am »
Do any motorcycle engines need core plugs? Car etc engines have massive castings forming the whole bottom end and cylinder block in one piece, bikes have relatively small components in comparison so less need to have holes left in castings to remove the media used to form cooling channels in and around the block
Of course some will prove me wrong but I've never seen one.
Love from notsuchanob.com
midden
Re: core plugs
« Reply #4 on: 16 September 2015, 02:32:45 pm »
The reason I asked the  (stupid to some)  question was after doing a coolant change there was liquid coming from apparent tube between 2nd and 3rd fin on first running the engine there seemed to be possible spray/steam from the same.  It appears to be ok now (touchwood)
(andthevoteistilloutonthatone.com)
Ebme Geek
Re: core plugs
« Reply #5 on: 16 September 2015, 04:08:33 pm »
That's a drain hole/passage to the spark plug well, there is another the other side, should be kept clear so any water that gets there can drain away  ;)
midden
Re: core plugs
« Reply #6 on: 16 September 2015, 04:37:50 pm »
Cheers for that Ebme, all has become clear now ;)
aworthyquestionafterall.com
joebloggs
Re: core plugs
« Reply #7 on: 16 September 2015, 10:42:23 pm »
Sorry if I got your back up
Cant help myself sometimes.
It wasn't a dumb question, or a dumb answer
Just banter
youllgetyourheadroundmesomedaymaybeifyourintherightsortofframeofmind.com  :lol
midden
Re: core plugs
« Reply #8 on: 16 September 2015, 11:48:07 pm »
Just banter
all is good no back was risen. Just throwing the banter back at ya  ;)
His Dudeness
Re: core plugs
« Reply #9 on: 17 September 2015, 02:36:55 pm »
I bet you're seeing the coolant on the right side of the engine? The thermostat where you put the coolant in is above that drain hole so any spillage when filling goes in there so I'd say it's just a bit of spillage
midden
Re: core plugs
« Reply #10 on: 18 September 2015, 12:05:22 am »
spot on  ;)
