Date: 22-04-26  Time: 08:53 am
Author Topic: Oooops I've bought another gen 1!!!  (Read 8397 times)
nickodemon
« on: 11 September 2015, 07:46:12 pm »
Bought this tidy gen 1 tonight. Lovely bike with 46'000 mls full service history. It has a couple of issues i will need to sort. The first is the rear shock which is as soft as sh*te, the second is the exup valve rattles (hopefully just needs adjusted and greased) The third issue is the carb rubbers are cracked. I have owned several gen 1's and have never had any where the carb rubbers are cracked... Do they need replaced or are they pretty thick and should be okay. I always remember my rd 350 lc rubbers cracking. They needed replacing :\
devilsyam
Re: Oooops I've bought another gen 1!!!
« Reply #1 on: 11 September 2015, 07:58:57 pm »
seen worse but there on well thick its just a cosmtic hang up
but looks a good un potential
RMT1983
« Reply #2 on: 11 September 2015, 08:46:40 pm »
Ive got a hyperpro spring and some rubbers if needed mate?
nickodemon
« Reply #3 on: 11 September 2015, 08:59:44 pm »
I might get back to you about the spring and rubbers ;) . I noticed when looking at rear shock it is set on the lowest spring setting? I will adjust up to max tomorrow and see how it feels. It doesn't need to be the best handling bike in the world, as it's purely for motorway slog to work..
nickodemon
« Reply #4 on: 12 September 2015, 12:06:25 pm »
Carb heater plumbing has been removed along with the ais kit, so someone who previously owned it has known a few of the mods :thumbup
nickodemon
« Reply #5 on: 12 September 2015, 09:34:13 pm »
The shock seems to be okay (for a standard shock!!!) It had all the settings at the softest settings? After some fettling it's better. i am going to take one of the carb tops off tomorrow and check the needles to see if it has been ivanised. It pulls really well and doesn't have the fluffiness of the standard set up. It has also had other mods done, so whoever owned it in the passed knew a thing or two about the mods.. Just bought a race can and link pipe from rmt1983, so i can get rid of the standard can..
solorider
« Reply #6 on: 13 September 2015, 11:31:11 am »
What benefits does removing the carb warming pipes make? I have removed mine because one of mine split causing a water leak, as Yamaha want stupid money for them I blanked off the inlet/outlet and removed the pipes.
Falcon 269
« Reply #7 on: 13 September 2015, 11:38:07 am »
No benefit unless you live somewhere really hot and have suffered from fuel vaporizing in the carbs on a hot day.
nickodemon
« Reply #8 on: 15 September 2015, 09:59:11 pm »
Next thing on the list was the rattling exup valve. Unbelievably the exup cover had 3 different bolts fitted and then when i removed the cover the bolts holding the exup to the exhaust were battery terminal bolts! They are as soft as sh*te!! The first snapped the head clean off, but i managed to get the other two out. :)  I removed the snapped one with big vice grips on the remaining thread and slowly removed it :woot I stripped the exup down thoroughly cleaned it and gave a light rub down until shiny. I then thoroughly coated in high quality heat resistant lithium or ceramic (grey stuff) grease, reassembled, adjusted cables and hey presto a perfectly functioning exup. Oh.. while i remember the spring that sits between the pulley and valve were missing, so i made one and it seems to work well. Fitted flip screen courtesy of clanadam. It was clear from top to bottom, so it showed behind the clocks , i masked it off and sprayed the bottom of the screen with some satin black paint. Looks good, hopefully it will work well. Find out tomorrow when going to work.
nickodemon
« Reply #9 on: 16 September 2015, 09:07:59 pm »
Screen works a treat :thumbup
clanadam
« Reply #10 on: 17 September 2015, 06:57:51 pm »
Good stuff - bad weather is just round the corner for the full test  :lol
slimwilly
« Reply #11 on: 17 September 2015, 07:13:25 pm »
Sounds like a nice commuter project going on.
devilsyam
« Reply #12 on: 17 September 2015, 07:53:19 pm »
Wot you doing with the double bubble screen nick
nickodemon
devilsyam
« Reply #14 on: 17 September 2015, 11:59:14 pm »
Wot no foccer deal?
nickodemon
« Reply #15 on: 18 September 2015, 01:56:49 pm »
I tried that with the bars and bar ends and got dicked about. :o
nickodemon
« Reply #16 on: 18 September 2015, 08:58:43 pm »
I got nice drizzle on way to work this morning...... :\
onejay
« Reply #17 on: 20 September 2015, 07:49:38 pm »
im interested in your views of the flip up screen
is it better than standard item
nickodemon
« Reply #18 on: 20 September 2015, 09:13:50 pm »
Its an excellent screen. I can sit at 80mph with no head buffeting at all. Here's a pic
JKay
« Reply #19 on: 20 September 2015, 10:55:26 pm »
Wots the make of the screen pls m8
nickodemon
« Reply #20 on: 20 September 2015, 11:02:23 pm »
No idea! Pm Clanadam as i bought it from him.
clanadam
« Reply #21 on: 20 September 2015, 11:37:05 pm »
Sorry can't help - it came with the bike when I bought it!
onejay
« Reply #22 on: 21 September 2015, 10:53:14 pm »
anyone know if the double bubble screens are any good
Falcon 269
« Reply #23 on: 22 September 2015, 05:58:45 am »
All depends on your height and build, and the type of screen you buy.  Not all DB screens for the Fazer are the same.
Which screen is best is a very subjective thing on the Gen 1.  What works great for one owner could be awful for another.  Start by getting views from those similar in size to yourself.
Didier9
« Reply #24 on: 23 September 2015, 01:22:46 am »
How hot does it need to be?
I live in Florida and made it just fine through the summer, commuting to work every day including going home for lunch. Now, I did not get stuck in traffic jams very much, just the occasional traffic light, so maybe as long as the bike is moving, it's not as much of a problem.
