Date:
13-04-26
Time:
11:23 am
Home
Media
old - Fazer Owners Club - old
Fazer8 / FZ8
Clutch Problem 2014 FZ8
« previous
next »
Print
Pages: [
Author
Topic: Clutch Problem 2014 FZ8 (Read 7212 times)
Mikeee
Cager in Training
on:
09 September 2015, 03:16:35 pm »
Hi
I have a problem with the gears on my new FZ8. When I drop the revs off ready to go down the box the clutch isn`t disengaging for a couple of seconds! This means there is still traction at the back wheel. A car pulled up quite suddenly yesterday and meant that I could`nt stop quite as quick as I would have liked. (The car was quite away in front of me and I was not in any real danger on this occasion!). I`m struggling to get a smooth change upwards too, I have to move the gear shifter twice to get the gear.
Anyone experienced the same or have any ideas what the problem could be?
Cheers
Mikeee
Logged
slappy
Naughty Corner
GP Hero
Re: Clutch Problem 2014 FZ8
Reply #1 on:
09 September 2015, 04:03:23 pm »
First thing to do is lube the clutch cable and then make sure the clutch is correctly adjusted.
Has it got standard clutch lever on or an aftermarket adjustable one?
I ask that as I have an aftermarket adjustable on my FZ1 and once when washing it I must have moved the adjuster and the clutch lever would then not pull the cable enough to engage and I could not get it into gear
Logged
Smurfbud
DAS Born Again
Reply #2 on:
09 September 2015, 04:55:52 pm »
Sounds like your clutch is not adjusted properly so the plates are not fully disengaging when you pull the lever in ....
Turn the adjuster 1 full turn clockwise when looking from the left of the bike (so you are extending the cable) then test ride and see if there is any improvement ... keep adjusting til sorted ....... you will soon find out
Logged
Mikeee
Cager in Training
Reply #3 on:
09 September 2015, 07:54:21 pm »
It's a standard leaver on the bike slappy. I'm off out on the bike tomorrow, I'll try adjusting the leaver and see if it makes a difference. I think the bike has been stood for a while, I wonder if the plates are sticking.
Logged
Print
Pages: [
« previous
next »
Fazer8 / FZ8
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
