Date: 12-05-26  Time: 19:44 pm
Author Topic: rider left footpeg loose  (Read 6676 times)
Paulfzs
« on: 30 August 2015, 07:17:36 pm »
more problems...
rider left footpeg is loose and has a lot of play...
how do i solve this?
slappy
Re: rider left footpeg loose
« Reply #1 on: 30 August 2015, 07:25:13 pm »
How does it actually fasten on?
Paulfzs
« Reply #2 on: 30 August 2015, 07:32:16 pm »
i cant quite tell, it goes through into the hanger but looks like possibility of a C clip
slappy
« Reply #3 on: 30 August 2015, 08:16:55 pm »
See if you can actually remove the footpeg, if so is the shaft where it fastens on worn, or if there are any bushes worn that would  cause it to feel loose.
Val
« Reply #4 on: 30 August 2015, 08:26:24 pm »
Actually there is big hex bolt part number 90109-103A9 at the back of the hanger (the heel plate). You need to remove the hanger first than unsrew the hex bolt and remove the foot peg.
Having said that what do you mean loose? Mine left foot peg has some free swivel play and can rotate a little about 30 degrees. I hope that is normal and by design  :lol
Paulfzs
« Reply #5 on: 30 August 2015, 10:19:00 pm »
its well loose!
looser than its ever been...
this loose...
« Reply #6 on: 30 August 2015, 11:57:06 pm »
Yes you need to undo the two hex bolts on the left as well as loosening the gear change leaver bolt ( mark the position on the shaft first) then slide off the whole lot.
The 10mm - i think hex bolt at the back of the kick plate from factory is fecking tight of tight town tighty so if yours is loose then it must of been removed in the past and not put back tight enough also it should have from factory a locktight on it. Take it out aply  locktight and do it up to tight - tighty town, tight
Val
« Reply #7 on: 31 August 2015, 12:18:05 am »
 :agree Looks to me your hex bolt is loose.
Paulfzs
« Reply #8 on: 31 August 2015, 02:36:32 am »
got it off....
twisted a hex key trying to get the hanger off!
the footpeg hex bolt was almost all the way out! done back up as tight as i could and all reassembled
« Reply #9 on: 31 August 2015, 11:32:52 am »
That's not a sudden thing, how have you not noticed that before?
Paulfzs
« Reply #10 on: 31 August 2015, 12:26:09 pm »
Its always been a little loose but recently i did do a big long ride which was bumpy country lanes and a lot of motorway so im guessing this just finished it off.
« Reply #11 on: 31 August 2015, 12:59:26 pm »
What physics are at play --- why is it that any vibration loosens a nut and not tightens a nut.
« Reply #12 on: 31 August 2015, 01:27:35 pm »
If your bike was an animal you'd be done for cruelty.  :rollin
« Reply #13 on: 31 August 2015, 01:33:10 pm »
Me thinks that you posted that one in the wrong thread
Should that have gone in the choke one
« Reply #14 on: 31 August 2015, 01:34:04 pm »
Nope!
« Reply #15 on: 31 August 2015, 01:35:26 pm »
« Reply #16 on: 31 August 2015, 02:04:06 pm »
Heard you the first time!
Nope!
« Reply #17 on: 31 August 2015, 02:49:28 pm »
Go on Fazersharp, tell him again  :rollin :rollin :rollin
« Reply #18 on: 31 August 2015, 02:53:32 pm »
Well I dont get it then
Paulfzs
« Reply #19 on: 31 August 2015, 04:10:31 pm »
Id get done for animal cruelty but id be up in court with about 4.8 million trees worth of receipts where ive bought parts and treated this bike but still it shows me so much hate.
« Reply #20 on: 31 August 2015, 04:28:39 pm »
 :lol
