Date: 13-05-26  Time: 00:22 am
Author Topic: carbs ballanced.. does it look okay? also video of rev counter...  (Read 5395 times)
Paulfzs
before:
After:
far left is a tiny bit out but fixed after this pic
Rev counter... not sure if its supposed to fluctuate this much but input?
Re: carbs ballanced.. does it look okay? also video of rev counter...
« Reply #1 on: 30 August 2015, 05:09:55 pm »
It's hunting a bit 'cos it's too low.
With the engine warm it should be around the 1200rpm mark.
Paulfzs
« Reply #2 on: 30 August 2015, 05:23:40 pm »
Ok brilliant, ill get it turned up a bit and let you know.
Paulfzs
« Reply #3 on: 30 August 2015, 05:47:19 pm »
turned the idle up to 1200 still hunting a bit, took it to 2000 and still hunting a little but not as much... putting this down to my carb rubbers.. any glue thatll seal the cracks?
« Reply #4 on: 30 August 2015, 06:25:22 pm »
Are you saying you have an air leak?
If so your carbs are falsely balanced.
Paulfzs
« Reply #5 on: 30 August 2015, 07:16:16 pm »
I dont think i do but the rubbers have small cracks, they dont appear to go all the way through
« Reply #6 on: 30 August 2015, 07:39:45 pm »
Silicone
anutz
« Reply #7 on: 02 September 2015, 03:21:54 pm »
where is your wiring connector box? or did you remove it for some reason?
Paulfzs
« Reply #8 on: 02 September 2015, 03:38:56 pm »
i did an engine change but before i did this i removed the box to get access to the top and then i lost it then found it again.. planned on putting it back but lost it again :D
plus weight reduction
anutz
« Reply #9 on: 02 September 2015, 03:42:44 pm »
weight reduction eh? i may go and remove mine later  :lol
the carb readings look sync'd mine were a tad out but i never tweaked owt, still runs fine, aside from a rattling chain but waiting for the tensioner to click...
Paulfzs
« Reply #10 on: 02 September 2015, 03:53:00 pm »
dumping the old standard exhaust made a massive improvement on speed and weight, the box just tipped it off and added around 0.01bhp
