Date: 11-05-26  Time: 23:44 pm
Author Topic: Fazer 1000 gen 1 2003 poor running low revs  (Read 2918 times)
Covertlaugh
« on: 15 August 2015, 11:18:57 pm »
Hi all. I have a Gen 1 Fazer 1000 2003 which I picked up in April as a do up. ( light cosmetic damage ) I have added a Ivan's full monty kit, akrapovic end can, modified the air box, pipercross filter,modified the manifold rubbers and balanced the carbs. On top of that I serviced the exup and the tps was fault checked ok. I have fitted new plugs and coils because it was firing on three cylinders which appears to have worked. However....the bike stutters and coughs around 2.5 to 3k when coming on the throttle or within that rev range and runs rough upto around 4k where it starts to clear and then takes off like an r1! If you nail the throttle from a start through to the red line then the stutter doesn't appear. It only appears in that rev area when you open the throttle. Today it was so bad as I rode through a village that the bike stalled and struggled to start again. The bike has 14k miles and appears looked after. Any suggestions?
Covertlaugh
Re: Fazer 1000 gen 1 2003 poor running low revs
« Reply #1 on: 17 August 2015, 09:48:12 pm »
Update...a friend suggested that when he used the. Piper cross / Akrapovic combination on his r1 it ran very lean low down. I had set the mixture screws as per instructions by Mike on carter soft for fitting Ivans full minty at 4.75 turns. I have now reset the screws at the full 5 turns out and it's just about sorted it. Worth remembering if anyone has the same combination.
Covertlaugh
« Reply #2 on: 29 August 2015, 03:55:53 pm »
Aaaaarrrgh! In fact it hasn't sorted it! Still there when I crack the throttle at 2.5 to 3k...stutter...stutter...stutter...whooooosh! Wtf! Anyone able to help me?
Covertlaugh
« Reply #3 on: 29 August 2015, 03:57:24 pm »
Is the Guru Mike the Falcon still about?
