Date: 26-05-26  Time: 04:54 am
Author Topic: K & N or Pipercross Air Filter with Remus can?  (Read 2001 times)
Just Fazered
« on: 15 August 2015, 10:24:22 am »
Pondering whether to fit a K & N or Pipercross Air Filter on my Gen 1 Fazer 1000, that I've just fitted a Remus can to?
What's your experiences?
Thanks in advance for your input.
Falcon 269
Re: K & N or Pipercross Air Filter with Remus can?
« Reply #1 on: 15 August 2015, 10:41:56 am »
I wouldn't recommend changing the filter from stock unless you have had the carbs rejetted.  Although the Remus can and a less restrictive filter will work well at higher revs, you might find that the fuelling gets a little lean at part-throttle lower down the rev range.  Not lean enough to cause engine damage but it could induce lean surge at around 4k rpm.
Of the two filters you mentioned, I'd go with Pipercross.  K&N filters for the Gen 1 frequently don't fit correctly without trimming the top moulding.
