Date: 12-05-26  Time: 10:47 am
Author Topic: sprocket cover oil leak  (Read 3272 times)
Paulfzs
« on: 06 August 2015, 03:08:00 am »
i think ive found the source of my oil leak, it appears to be from one of the bolt holes :S
the sprockets been off and no oil behind, clutch rod no oil, gear shaft no oil and a bolt hole seems to be full of oil..
now what?
the oil leak is noticeable after like 30+ miles itll leave a puddle the size of 2 50p coins.
Re: sprocket cover oil leak
« Reply #1 on: 06 August 2015, 06:02:42 am »
Would that be suggesting a cracked casing then?
Sounds a bit like this:
http://www.gixxer.com/forums/showthread.php?t=240279
Paulfzs
« Reply #2 on: 06 August 2015, 02:12:39 pm »
could be a cracked case, would be cracked inside the bolt hole itself :/
ptfe tape on the bolts i think then and see what happens.
« Reply #3 on: 06 August 2015, 02:57:09 pm »
It's not good whichever angle you look at it unfortunately.
Try the tape though, you certainly have nothing to lose.
Paulfzs
« Reply #4 on: 06 August 2015, 04:09:37 pm »
no idea how it could have cracked, engines only done 23k miles!
ill investigate!
« Reply #5 on: 06 August 2015, 04:55:35 pm »
ill investigate!
Over tightening the bolts would be my guess.
Paulfzs
« Reply #6 on: 06 August 2015, 05:15:51 pm »
ill investigate!
i blame sinto!
ill sort it, i always do..
even if it means filling it with jb weld!
Paulfzs
« Reply #7 on: 28 August 2015, 01:33:33 am »
so finally attacked this...
took cover off gave it all a wash out, the right hand side bolt was covered in oil when i took it out and a little oil dripped out the bolt hole so yep...
upon looking the reason its actually coming out is....
the sprocket cover bolt guide we will call it had 2 notches cut out of it, not sure if thats how theyre made (someone confirm?) and the bolt looked like its been caught on something and flattened the thread on 2 parts of it which appear to line up with these 2 big notches :S maybe something happened and damaged them both?
i wrapped it in a metric fuckton of ptfe tape and bolted it back together, and as of yet ive only had maybe 2-3 drops of oil which ill guess are whats left inside the casing/side of engine.
