Date: 26-05-26  Time: 04:53 am
Author Topic: Occasional problem changing gear  (Read 2573 times)
jeffco
« on: 04 August 2015, 08:00:46 pm »
For a while now I seem to have a problem changing down gears if I have brought the bike to a stop without down changing as I slowed, when im stopped and I try to change down it will go down to about 3rd them wont go further without a bit of jiggling about. Other than that the gearbox is fine, no missed/ sticky  gears  and changes down fine if I change down as im slowing. Is this a common problem? or are dark clouds forming on my horizon ?   You can tell that ive just had a week in Scotland , still looking for bloody dark clouds...
Re: Occasional problem changing gear
« Reply #1 on: 04 August 2015, 08:12:37 pm »
That would be normal enough as the gears need to be rotating to mesh properly.
Let the clutch in and out a bit to get the gears to rotate a bit to the correct position when changing at a standstill.
ste131
« Reply #2 on: 04 August 2015, 08:29:58 pm »
Yeah, its normal. It has to select through rotation. Just go down the gears before you stop or slip clutch. Catches us all out sometimes when we think brakes first!
jeffco
« Reply #3 on: 04 August 2015, 08:45:29 pm »
Thanks lads.... It only happened cos it was pissing down and I had to stop pretty sharp, I was more concerned about staying on it than changing gears.
« Reply #4 on: 05 August 2015, 12:04:04 am »
I guess most of us have been in that situation once or twice  :lol
