Date: 21-04-26  Time: 04:36 am
Author Topic: 2nd gear gone again  (Read 3069 times)
bigfootpete
2nd gear gone again
« on: 02 August 2015, 11:46:01 am »
Are these gears made out of tin foil? This is the second time my second gear has lost teeth.
Ok, first time I tried too many wheelies, but I don't bother with those any more. My gear changing is smooth - mostly :-)
Are aftermarket gear cogs any better?
AyJay
Re: 2nd gear gone again
« Reply #1 on: 02 August 2015, 12:07:04 pm »
Is it a 2001 model? The second gear on R1s and Fazers 2000/2001 were superseded by an uprated part. Poor undercutting on the dog, apparently. See "Replaced part number" here
https://www.motorcyclespareparts.eu/yamaha-parts/motorcycles/fzs1000-fazer-2001/transmission-348946/5jj171210000-gear-2nd-pinion.aspx
Mark YPVS
« Reply #2 on: 04 August 2015, 07:44:18 am »
make sure when  you change 2nd you change 6th and the selector fork as well, had to do my R1 5PW ( same gear box).
Mark :)
sirgalahad3
« Reply #3 on: 04 August 2015, 01:38:22 pm »
If you follow the line back Yamaha suffered from the same problem on the xs1100. Second gear on them was very fragile on them and they didn't seem to correct it on the early 1000 boxes. Mine is 03 and seems ok but being a xs11 owner I never harsh change second...
bigfootpete
« Reply #4 on: 04 August 2015, 07:30:21 pm »
It's a 2003 model, thanks will make sure I get 6th and selector done too.
« Reply #5 on: 04 August 2015, 08:09:45 pm »
The uprated 2nd gear (again) part number is 5JJ-17121-01 not 5JJ-17121-00 it was changed again in the later fazers
bigfootpete
« Reply #6 on: 31 March 2017, 01:53:05 pm »
Me again, talk about procrastinating! I've been riding around mostly changing straight up to third to avoid second.
Just ordered the gears, but apparently there are three selector forks, so anyone know which one to replace?
