Date: 12-05-26  Time: 13:02 pm
Author Topic: oil light?  (Read 11769 times)
mr wayneker
oil light?
« on: 29 July 2015, 07:21:45 pm »
just going up a hill and the oil light flicked on then off
just had oil change two weeks ago...checked oil and around and no
leaks.....any ideas
Re: oil light?
« Reply #1 on: 29 July 2015, 07:47:18 pm »
How did you check the oil level?
Re: oil light?
« Reply #2 on: 29 July 2015, 08:01:20 pm »
Turn engine on for about 30 seconds, switch off, and watch the oil settle in the window.
That will be your oil level.
You want it about two thirds up between the lower and upper level engine case markings next to the window.
It's an oil level light, not pressure, so I'm guessing you simply don't have enough oil in it.
Top up a tiny bit at a time then repeat the above steps, do not over fill it.
mr wayneker
Re: oil light?
« Reply #3 on: 29 July 2015, 09:52:10 pm »
it was quite a steep hill and under acceleration. Could it of given a false reading momentarily?
Re: oil light?
« Reply #4 on: 29 July 2015, 10:38:38 pm »
Yes, but, it shouldn't really if at the correct level.
Bike on centre stand on level ground, start engine for 30 seconds, then watch the window for a minute and all will be revealed.
Jules-C
Re: oil light?
« Reply #5 on: 29 July 2015, 10:43:55 pm »
Some people have experienced the same thing with the light coming on once or twice while accelerating up hills. If it only happens very rarely its nothing to worry about if the oil level is OK when you check it
mr wayneker
Re: oil light?
« Reply #6 on: 30 July 2015, 06:41:17 pm »
I think that's all it is to
His Dudeness
Re: oil light?
« Reply #7 on: 31 July 2015, 01:44:42 pm »
Did you measure the number of litres of oil you put in? Was it what the manual says to put in? If yes then you've nothing to worry about ;)
mr wayneker
Re: oil light?
« Reply #8 on: 31 July 2015, 02:58:12 pm »
got them garage people to put it in when I had the bike looked over..just after I bought her
a question  :o if I was to take the clutch cover off would any oil come out
and would I have to replace the gasket :o :o :o
His Dudeness
Re: oil light?
« Reply #9 on: 31 July 2015, 03:30:42 pm »
If you leave it for a few hours and put it on the sidestand you shouldn't lose any oil but why do you want to take the cover off? You won't be able to tell if the oil is low from that. You'll have to drain it and refill it with the correct amount to be sure
Re: oil light?
« Reply #10 on: 31 July 2015, 05:20:01 pm »
Have you not checked the level yet?
Just follow the easy steps I wrote above, the window is down low on the right side of the sump.
mr wayneker
Re: oil light?
« Reply #11 on: 31 July 2015, 09:46:13 pm »
yeah checked level darrsi allllllllll good
dudeness its for when I get a new clutch cover...not to check oil :D
Re: oil light?
« Reply #12 on: 01 August 2015, 03:06:37 am »
Lay the bike on lots of bubble wrap.....sorted  :thumbup
Jules-C
Re: oil light?
« Reply #13 on: 01 August 2015, 08:05:05 am »
And you will need a new gasket. Make sure the engine casing has any traces of the old gasket removed before you fit the new one
gerkin
Re: oil light?
« Reply #14 on: 03 August 2015, 06:26:07 pm »
ive had this ,its ok if oil level is at its highest in the site glass but comes on if near the lower mark
Re: oil light?
« Reply #15 on: 03 August 2015, 09:50:58 pm »
Thats about an egg cup difference isnt it
Re: oil light?
« Reply #16 on: 03 August 2015, 11:06:36 pm »
Yes, if your bike has an oil sump the width of an egg cup!
noggythenog
Re: oil light?
« Reply #17 on: 03 August 2015, 11:29:02 pm »
Ostrich egg cup Darrsi
Switch on will ya :pokefun
mr wayneker
Re: oil light?
« Reply #18 on: 07 August 2015, 07:51:17 pm »
ok so went up the same hill today annnnnnnnnnnnd nothing so must have been a glitch :z
Re: oil light?
« Reply #19 on: 07 August 2015, 10:57:14 pm »
you were just slower
Re: oil light?
« Reply #20 on: 08 August 2015, 07:21:19 am »
Did you actually ever check the oil level, as above?
mr wayneker
Re: oil light?
« Reply #21 on: 08 August 2015, 08:29:02 pm »
 ;)post #12 darrsi
Re: oil light?
« Reply #22 on: 08 August 2015, 09:09:30 pm »
;)post #12 darrsi
Apologies,  I overlooked that one.  ;)
Re: oil light?
« Reply #23 on: 17 August 2015, 12:30:08 pm »
My oil level is correct and again yesterday I managed to get the light to flick on for a split second, it was during a straight across a quiet roundabout move  ;) .
So im thinking the red light is more of an angle/acceleration indicator.  :b
stevierst
Re: oil light?
« Reply #24 on: 17 August 2015, 01:23:51 pm »
Both my R1'S and my gen 1 had the same oil light problem, but only when it's cold and level is somewhere in the middle. If I top it up to the max mark, it doesn't happen.
When the light comes on as I'm rolling along, pull in the clutch, flick the kill switch off, and let the engine die. Kill switch to on, and restart. Light goes out and I just carry on without any further incident.
Get home after the ride and top it up.
