Date: 07-05-26  Time: 11:16 am
Author Topic: Brake advice  (Read 1960 times)
dilboy
Brake advice
« on: 20 July 2015, 02:56:17 pm »
Hi all
I'm going to attempt to change my brake pads and fluid, as this is my first attempt and advice would be most helpful
cheers
Novice  :)
Val
Re: Brake advice
« Reply #1 on: 20 July 2015, 04:17:15 pm »
Hi all
cheers
Novice  :)
Decide which pads you will use EBC organic or some hard sintered ones. Personally I like soft controlled action of the organic pads, and the fact that they do not eat the discs the way hard sintered pads do. Fazer front discs are expensive.
Clean well the calipers before you put the new pads, I usually add a little copper greaze on the back of the pads.
Get this thing Gunsons easybleed:
http://www.halfords.com/motoring-travel/tools-diy/tools-tool-kits/gunson-eezibleed
Do not forget to tie your brake lever over night and pump well in the morning too.
dilboy
Re: Brake advice
« Reply #2 on: 20 July 2015, 10:10:26 pm »
cheers for the advice :)
