Date: 07-05-26  Time: 03:14 am
Author Topic: Can't get neutral  (Read 2524 times)
HJFazer
Can't get neutral
« on: 17 July 2015, 07:29:07 pm »
Hey, so assistance needed please.
Even with clutch in I can't get neutral and it won't start in gear.
I think the cable must be too stretched and do not fully engaging causing the above.
Does that sound right? Any thoughts on fixing it?
Have changed the levers a few weeks ago so night try the old one in the hope it pulls it enough.
Help appreciated,
Haydn
His Dudeness
Re: Can't get neutral
« Reply #1 on: 17 July 2015, 08:51:58 pm »
Have you tried rocking it back and forward while changing gears? Is your chain very slack?
HJFazer
« Reply #2 on: 17 July 2015, 09:20:28 pm »
Got it in eventually. Chain is within the tolerance but at the lose end of it.
Think it might need a new cable as it's pretty slack and I'll tighten the chain as well.
Cheers
« Reply #3 on: 17 July 2015, 09:42:25 pm »
Cheers
Check the clutch adjustment at the Sprocket cover side.
« Reply #4 on: 17 July 2015, 10:06:00 pm »
Cheers
+1 to that.
Lower end first then tweak at the lever end.
HJFazer
« Reply #5 on: 17 July 2015, 11:32:00 pm »
Cheers guys, will have a play tomorrow
Jules-C
« Reply #6 on: 18 July 2015, 09:14:47 am »
Check the sprocket cover screws are tight. They have been known to unscrew giving the same symptoms as a stretched cable
