Date: 25-04-26  Time: 04:02 am
Author Topic: Fz misfiring...  (Read 3575 times)
Mike01
Fz misfiring...
« on: 29 June 2015, 08:13:38 am »
Morning.
So the bike has been fine for the short time i have owned it and nearly 1k miles i have done so far...
Last used it Saturday with no problems, got it out of garage an hour or so ago, started fine, ticked over fine for few mins then after 500 yards or so of very slow riding it started to misfire.. Bliped the throttle a few times but it would not clear  :\
So its back in my garage and i had to use the car on this beautiful day  :'(
Will have a look tonight when i get home, will start with leads and plugs... Is there a common problem i should check for??
Thanks.
slappy
Re: Fz misfiring...
« Reply #1 on: 29 June 2015, 02:45:36 pm »
Check every eletrical connection you can get at,  pull them apart and check for corrosion.
Fuel filter and air filter ok?
I assume there is petrol in tank :)
devilsyam
Re: Fz misfiring...
« Reply #2 on: 29 June 2015, 02:48:49 pm »
I had this recently on customers bike build prior to strip down for paint was fine after misfired took some advice front mike and clipped 1/4 off each ht lead problem sorted well worked for me
Mike01
Re: Fz misfiring...
« Reply #3 on: 29 June 2015, 02:57:10 pm »
Did a quick google, our US buddies have this a fair bit and mostly falls down to coils.
I will have a look later when i get home but yes will check all connections and there is over 1/2 tank fuel
Thought the HT leads plugged directly into the caps, not sure if you can cut these down?
Mike.
Mike01
Re: Fz misfiring...
« Reply #4 on: 29 June 2015, 05:50:34 pm »
So it's missing on #2, now to work out how to get the lead/caps off.... #space....
Mike01
Re: Fz misfiring...
« Reply #5 on: 29 June 2015, 06:02:56 pm »
It's not the coil... Swapped that round and 2 still missing...
slappy
Re: Fz misfiring...
« Reply #6 on: 29 June 2015, 06:03:46 pm »
When you have managed that tell me how  :), I was looking at mine other day and it looks even tighter than the gen1
slappy
Re: Fz misfiring...
« Reply #7 on: 29 June 2015, 06:04:44 pm »
Swap plug over
Mike01
Re: Fz misfiring...
« Reply #8 on: 29 June 2015, 06:05:10 pm »
Fairly easy to be honest, drop rad from mounts, pull down and access from top
Mike01
Re: Fz misfiring...
« Reply #9 on: 29 June 2015, 06:16:35 pm »
 :) :D
Plugs fooked :D
slappy
Re: Fz misfiring...
« Reply #10 on: 29 June 2015, 07:04:50 pm »
At least you know the cause of the misfire now, how many miles have they done?
Mike01
Re: Fz misfiring...
« Reply #11 on: 29 June 2015, 07:10:32 pm »
All 12k I would say, just grabbed new set from Halfords..
Mike01
Re: Fz misfiring...
« Reply #12 on: 29 June 2015, 08:02:35 pm »
New set in and running sweet  :D
