Date: 06-05-26  Time: 23:05 pm
Author Topic: What have you done to your FZS600 bike today  (Read 314649 times)
« Reply #550 on: 18 May 2017, 10:22:16 am »
only 12x8 (wife free zone) but big enough for bike bench chair tools etc , saving up for a sealey space saver lift next
Great looking shed Matt.
If the floor in your new shed is tongue and groove boards timber (T&G) place a piece of 3/4 inch ply under where the life will live, the casters on the lift may disappear  through the 8mm thick T&G boards and end up with your bike laying on its side after falling 2 or 3 foot from the lift.
kgjersda
« Reply #551 on: 19 May 2017, 03:58:29 pm »
Just got my FZ400 Fazer headlamp and my rear blue spot caliper!
Bike is getting a hell of a lot safer :D
savvy
« Reply #552 on: 19 May 2017, 07:07:45 pm »
Fitted heated grips.
matt7chunk
« Reply #553 on: 19 May 2017, 10:21:04 pm »
Cheers bud, already thought of that lol laying 18mm osb3 throughout for a bit more strength
« Reply #554 on: 20 May 2017, 06:22:27 am »
Iam with tommy.....good quality ply is a lot stronger than OSB ......I would cut a 300mm square of 25mm ply just for the center stand to sit on and another piece for your new space saver lift.....theres a lot of weight in a small area  , peace of mind and all that......
« Reply #555 on: 20 May 2017, 11:39:13 am »
First time?
Best thing ever, would never ride without them now.  :thumbup
savvy
« Reply #556 on: 20 May 2017, 07:08:53 pm »
No not first time Darrsi, had them on Duc ST then VFR but only just got round to the FZS. Been off the road for a year due to house move and renovation but old age now requires them sooner LOL. :'(
savvy
« Reply #557 on: 20 May 2017, 07:23:50 pm »
kgjersda. I fitted FZS400 headlight to my 600 boxeye also about 18 mths ago. Got the wiring diagram from either this or previous site. Can see where the roads are now.
 Think I still have the diagram saved somewhere :lol
« Reply #558 on: 20 May 2017, 11:42:08 pm »
is the 400 seriously much better then the 600 - ive gone vertical dominators now but good info to know
kgjersda
« Reply #559 on: 21 May 2017, 12:22:27 pm »
I ordered the part from Russia. So I HOPE that its a right hand side headlamp. I live in Norway. If not i've got a headlamp for sale 😁
kgjersda
« Reply #560 on: 21 May 2017, 02:51:47 pm »
I've hooked up the 400 headlamp to a battery and tried to see the pattern.. But I can't really make out if it's left hand side vs right hand side. Is there an easy test I can do to check? I can't find the serial number on the headlamp either. All the numbers are identical to the one installed on the bike already. (but the reflectors and bulbs are obviously different.
« Reply #561 on: 21 May 2017, 04:09:46 pm »
Apparently the 400 Boxeye headlamp reflector and setup is much, much better than the 600 Boxeye.
My understanding is that both of the bulbs (2 X H7 twin filament bulbs ) on the 400 Boxeye are the same as the 600 foxeye, so both bulbs are H7 and the same so both beams are on by default on the 400 headlight set up, but again if my understanding is right (Please correct me if i am not) that they still fall short of the Foxeye head lamps because of the foxeyes larger reflector and better design.
« Reply #562 on: 21 May 2017, 10:05:25 pm »
The bulbs on a 600 are H4 high beam and H1 low beam, the 400 is 2 H4's.  On the 400 the both bulbs are on for low and high unlike the 600which has H1 for low beam and H4 for high beam and only the high beam filament works.  The reflectors on the 600 are also only low/high beam for each side/bulb.  Even when the 600 is modded so both are on, its still a big trade off as the high beam reflector has to be lowered to stop dazzling on coming, which then means loss of high beam.   The 400 has dual reflectors and all filaments on the bulbs work.
Quite why the 600 has such a piss poor set up is beyond me just penny pinching perhaps.
kgjersda
« Reply #563 on: 22 May 2017, 09:58:39 am »
According to what I can decipher there is no left/right headlamp for Japan.
This site lists 4YR-84310-00-00 as part number, with 5DM-84310-00-00 as the replacing headlamp.
https://en.impex-jp.com/catalogs/moto/yamaha-other/FZ-400/31791/Headlight__assy-971876.html
The GBR headlamp uses the part code 5DM843101000, while the rest are 5DM843100000.
https://www.motorcyclespareparts.eu/yamaha-parts/motorcycles/fzs600-2000/headlight-347509.aspx
« Reply #564 on: 22 May 2017, 10:19:15 am »
when i took my fairing off and pulled apart the headlights i was shocked that it was a h1/h4 setup and instantly took a dislike to it
i run dominator headlights in a stacked posistion using good h4's in both
the bike had been dropped by previous owner and the fairing was cracked and frame twisted so it was the easiest option for better lights
-wish i knew then what i know now
« Reply #565 on: 22 May 2017, 10:42:32 am »
Japan drives on the left the same as we do so there wouldn't be a different part number for the 400 headlight as it was only ever made for their home market.
« Reply #566 on: 22 May 2017, 10:44:16 am »
Why?
The EU regs at the time only allowed a single dipped beam light. H1 or H4 makes no difference. 55w is 55w.
The best fix is HIDS but if you want dual lights on for dipped it is a single cable to run from under the tank to the H4 top connector.
kgjersda
« Reply #567 on: 22 May 2017, 10:46:26 am »
That might be so. But the replacement for the out-of-production FZ400 headlamp is the same number as the standard headlamp, not the GBR headlamp.
kgjersda
« Reply #568 on: 22 May 2017, 10:48:00 am »
Fitted the rear blue spot caliper and new Pilot Road 3 tires both front and back.
What a difference!
Fazer99
« Reply #569 on: 22 May 2017, 10:54:10 am »
What a difference!
Looking good, is that side panels you have fitted? any chance of some pictures as I've never seen a fully faired Fazer before?
kgjersda
« Reply #570 on: 22 May 2017, 10:58:29 am »
Sure thing. Previous owner had a bit of a tumble so I repainted them with rattlecans.
I believe these are the same: http://www.ebay.co.uk/itm/YAMAHA-FZS-600-FAZER-1998-2001-TUNING-SIDE-FAIRINGS-PANELS-LEFT-RIGHT-/160660732338?hash=item25682039b2:m:mvQqV5iycjZzEpNGFvLuaCA
Fazer99
« Reply #571 on: 22 May 2017, 11:28:42 am »
Very Nice  8) I would get some for my  :faz but it's that Vivid Coctail Red paint job which is a complete Foccing pain in the arse to colour match and I wouldn't want to have to payout to re-paint the whole bike. However, I will keep it in mind for if I ever had a fall and it had to be re-painted any way, but fingers crossed that won't happen  :lol
bigsteve
« Reply #572 on: 25 May 2017, 03:48:20 pm »
  After a long long hunt and a chance encounter  final got the screen I've been after
vinnyb
« Reply #573 on: 26 May 2017, 06:13:53 pm »
Cool but you're missing a screw.
bigsteve
« Reply #574 on: 26 May 2017, 07:05:41 pm »
new screws arrived today and all fitted now
  good spot  ;)
