Date: 08-05-26  Time: 06:05 am
Author Topic: engine surging/hunting  (Read 2725 times)
Paulfzs
« on: 12 June 2015, 08:25:55 pm »
not sure how long its been doing it i think quite some time now but it wasnt noticeable as much untill i put my new exhaust on and i can hear it.
idle at 1200rpm but bounce up and down about 300rpm or so, not eratic but every few seconds itll go up then settle.. when riding along at a constant throttle i can just about feel it but can hear it in the exhaust tone.
ideas?
noggythenog
Re: engine surging/hunting
« Reply #1 on: 12 June 2015, 08:46:43 pm »
Needs the carbs balanced
Paulfzs
« Reply #2 on: 12 June 2015, 09:03:42 pm »
i thought as much, i balanced them before, but new exhaust and a carb clean i had to rebalance but i think i did #4 out and just gave up with "close enough"
Frosties
« Reply #3 on: 12 June 2015, 10:30:25 pm »
ideas?
Could be the onset of involuntary Ticks  :lol
« Reply #4 on: 13 June 2015, 07:29:02 am »
Plug caps/HT leads, air filter, then carb balance would be my first actions.
Had "hunting" problems years ago on a bike and it was iffy HT leads, even worse in wet/damp weather.
Also check TPS, if that's iffy it will give similar symptoms too.
Paulfzs
« Reply #5 on: 13 June 2015, 11:15:38 am »
best not be leads, cant change them on the fzs has to be new coil :(
ill change the caps because it can only make it better even if i dont notice it.
tps was fine when i last checked about 1000 miles ago.
« Reply #6 on: 13 June 2015, 11:23:05 am »
No harm in taking a few seconds to check the TPS again, a lot can happen in 1000 miles!
Cut 5mm off end of HT leads to start afresh, these are good replacements:
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.TRS0&_nkw=SD05F&_sacat=0
Or if you want......brace yourself......buy 4 of these.  :D
https://www.yamahamotorcyclespares.co.uk/product/YAMAHA/5DM823700000/PLUG%20CAP%20ASSY&uid=0
Paulfzs
« Reply #7 on: 13 June 2015, 09:55:10 pm »
#1 and #2 can't be cut they appear to have been cut before they only just fit as it is.
i have 1 new plug cap as i bought it to replace #1 which kept breaking when wet
