Date: 08-05-26  Time: 00:47 am
Author Topic: Rear Caliper seal...  (Read 3159 times)
anutz
« on: 10 June 2015, 10:12:29 pm »
So when i took off my OEM caliper i thought it was toast....so put a 1000 caliper on it...
Now that i know a little more....or have done a lot with the front and rear braking i think it will actually be salavagable....
But i have lost a little "O" ring seal i think
Anyone know what part this is, i cannot see a caliper expanded to this level in parts catalaogs...
The seal goes i think in the recess on the second pic, of course these are the 2 "halves..." of the caliper...
Re: Rear Caliper seal...
« Reply #1 on: 10 June 2015, 10:21:49 pm »
Someone posted this site some time ago and they do the full set of seals for the FZS600 rear caliper.
http://www.powerhouseautomotive.co.uk/content/motorcycle-brakes/motorcycle-brake-caliper-services.php
anutz
« Reply #2 on: 10 June 2015, 10:23:39 pm »
ah never thought of checking them!!!
I shall see what they have, would be nice to get it back in working order....
anutz
« Reply #3 on: 10 June 2015, 10:34:02 pm »
OK so they DO have the so called 1/2 joint seals....which is good...
celticdog
« Reply #4 on: 12 June 2015, 01:02:58 am »
O rings, don't you just love 'em. You compress them axially they expand radially! Have you got a pair of vernier calipers handy? It's a standard engineering part, with a bit of work you should be able to source what your after for a few bob  ;)
limax2
« Reply #5 on: 12 June 2015, 08:21:53 am »
A few years ago someone on this site said the seal for a Suzuki GS500 rear caliper was the same. Pt Number 6910734200.
Wemoto show the size as 6.5 x 11.5 x 2.2
Not used it myself so I can't confirm that info.
anutz
« Reply #6 on: 12 June 2015, 08:48:56 am »
Thanks for the responses guys, so i will have a look on fleabay, will be sure to find what i need...
When i find out will let you know....i have all i need to rebuild apart from these 1/2 seals!
Pickle
« Reply #7 on: 12 June 2015, 10:07:03 am »
If you are buying O-Rings on Fleabay be aware of the type of rubber for brake fluid compatibility.
Buna - NO
Nitrile-NO
EPDM - YES
AFLAS - YES
anutz
« Reply #8 on: 12 June 2015, 10:30:11 am »
thanks pal....will make sure i do my research..
i picked up another rear on ebay for 10£ last night - at that price i could not pass on it - i will open that up and post pics of the seals as well..
once i am done i should have a couple of nice condition rear calipers, my old one and this one...
paulchucky
« Reply #9 on: 12 June 2015, 05:05:10 pm »
auntz meassure the seals with veneer gauge
 let me have the size and i`ll send you some foc
 i`m a plumber/boiler engineer and have 100`s ov the little rubber foccers
anutz
« Reply #10 on: 12 June 2015, 05:34:12 pm »
thanks, i shall do that, the 2nd caliper will be here next few days so will split it and let you know - thanks a lot!
