Date: 07-05-26  Time: 11:16 am
Author Topic: Worn Front Sprocket....  (Read 6007 times)
anutz
« on: 06 June 2015, 12:32:27 pm »
My front sprocket is show here, there were comments on an older thread it is worn, and after a bit or research i think it is as well....
I intend to replace it and also the chain and rear sprocket as i know it should be done as a set....
Any comments and also any one used the +1 front sprockets - real noticable affects....????
sinto
Re: Worn Front Sprocket....
« Reply #1 on: 06 June 2015, 12:39:34 pm »
Looking at yours anutz, I think i've something missing, the washer for starters :(
I'll need to investigate more into this I think :eek
anutz
« Reply #2 on: 06 June 2015, 12:44:49 pm »
not sure - i can see the lock washer tabs bent over on yours so not sure what else it needs...
I have since changed mine ( 12mm nut now ) but was looking at the old thread and someone said the front sprocket was worn and it does appear to be so i may as well dort it all now as i am putting an R6 shock in as well so will do it all at once before the MOT
« Reply #3 on: 06 June 2015, 12:47:11 pm »
Oops.
They're both the old 9mm nut as well, you need to fit the new 12mm nut, and safety washer, whenever you can.
Neither look unsafe though for now.
« Reply #4 on: 06 June 2015, 12:48:03 pm »
Blimey, you changed that quick.  :lol
sinto
« Reply #5 on: 06 June 2015, 12:52:54 pm »
Oops.
Your probably right darrsi, although I have read somewhere if it's not gone bad by now it should be ok, not to sure though, it does seem solid enough and my bikes done 24,000 now :)
There's pics here  http://foc-u.co.uk/index.php/topic,17216.0.html by riedrider showing his old and new.
I was more looking that there is differences in the picture of mines and anutz, thought they should look the same, mines looks more recessed tbh
anutz
« Reply #6 on: 06 June 2015, 12:55:14 pm »
blink and you would have missed it  :rollin .....did it a few months back but the only sprocket pic was the old one - its worn yes?
« Reply #7 on: 06 June 2015, 12:57:03 pm »
Took my mechanic about 40 minutes to get my nut off, as it had fused itself onto the shaft.
That all just sounds so wrong.  :rollin :rollin :rollin
sinto
« Reply #8 on: 06 June 2015, 12:59:03 pm »
:lol Yeah,  that's too much info :rollin
« Reply #9 on: 06 June 2015, 01:00:15 pm »
I wouldn't have said it was in particularly bad shape to be honest.
