Date: 07-05-26  Time: 15:43 pm
Author Topic: Bikes a bit poorly  (Read 1884 times)
Fizzy Pies
  • Guest
Bikes a bit poorly
« on: 01 June 2015, 07:16:42 pm »
Think all the abuse it got at spring meet has left it's toll on the old thing.
worked fine all week to work and back untill we went to go for a ride Saturday morning and it wasn't running on all four.
actually sounded like a twin so I thought a coil had gone so took caps off one at a time and cracked it next to the casing, each lead was offering a spark. i also checked the wires going to the coils and the caps leads etc. so took the plugs out, iridium about 15k old, all were spot on except one from the inner left cylinder sat on the bike, the end of this one was ok but the threads were black and looked a tad oily.
New plugs and it ran on four to southport and back, but it was hunting on idle.
tried to go work today, not running on four again.
think me biggest problem is a just can't be arsed anymore :-/.
I'd have another tho they're great bikes :-)
His Dudeness
Re: Bikes a bit poorly
« Reply #1 on: 02 June 2015, 01:34:58 am »
It's a mechanical system things wear out and break. Don't feel down about it it's still a good bike it just needs a small fix. Does it happen more when the bike is wet? You're dropping a cylinder and you've tried new plugs and it's still not running right but with the plugs out you're getting good spark so that rules out a few things for now. You can assume the plugs and coils are probably good. Next I'd do the old trim the leads and see if that helps. The leads degrade over time and the insulation cracks breaks down and they start to arc to the head and you loose spark. It seems to happen worst at the ends of the lead where they screw into the cap so try trimming a bit of lead off the end. Did that help? Next I'd try swapping the caps around, taking note which cylinder was the dodgy one. Did the problem follow the cap? If not I'd try wrapping the leads in insulation tape as a temporary way of ruling them out. Did that help? I think you can assume the coils are good but still it'd be no harm swapping them and going for a ride. Did the problem move to a different cylinder? Do that stuff first because it's the easiest. If none of that helps you'd probably want to check the carb on the dodgy cylinder. It could be over fuelling on that cylinder. So check the float and needle and make sure it's seating right and at the correct height. Give the carb a good clean and that'll probably sort it. Have you done any work on the carbs before? What mileage is on the bike. I'd say they just need a good clean.
Paul
« Reply #2 on: 08 June 2015, 05:28:06 pm »
To Fizzy Pies
If you don't make it round tonight I have some info for you.
The spare plug cap doesn't register any continuity.
So I stuck it on my bike and it worked fine.
Checked the one I took off my bike and that didn't register any continuity either.
My guess is, they're suppressed and don't have continuity when checked with a regular multimeter.
