Date: 07-05-26  Time: 20:36 pm
Author Topic: Oh no.....not another bolt....  (Read 10833 times)
anutz
« on: 29 May 2015, 06:29:05 pm »
OK so i have really messed up again  :'( :'( :'( :'( :'( :'( :'(
Snapped a front mud guard bolt and i really am annoyed - was using a torque wrench to get it to 7NM but it just span round and round then snapped....WTF can i do about this!
yes i can ride without a fender but want to fix it....OMG
Paulfzs
Re: Oh no.....not another bolt....
« Reply #1 on: 29 May 2015, 06:44:13 pm »
get drilling!
anutz
« Reply #2 on: 29 May 2015, 06:50:08 pm »
i am thinking left had drill bits might be best here after what i learned when the exhaust studs snapped.....
Andy Clap
« Reply #3 on: 29 May 2015, 06:52:18 pm »
get drilling!
As the man said.
That's one bolt I would never have thought of using a torque wrench on.  Maybe something to be said for "Feels about right".
anutz
« Reply #4 on: 29 May 2015, 06:54:36 pm »
it was a cyclo-torque wrench specifically for low torque - and the service manual does state 7NM....so i figured i would do it right  :\
Paulfzs
« Reply #5 on: 29 May 2015, 07:01:21 pm »
7nm new, as above "feels tight enough" is what id use for this.
anutz
« Reply #6 on: 29 May 2015, 07:07:49 pm »
Relief.....manged to grab the tinest piece of it and it came out with ease with a pair of neddle nose pliers!!!!
WOHOOOO!
I might just get this back together - eventually!
« Reply #7 on: 29 May 2015, 07:10:41 pm »
Are you sure the torque wrench was set to 7Nm and not set to 7lbf.
« Reply #8 on: 29 May 2015, 07:12:13 pm »
Were you using copper grease?
anutz
« Reply #9 on: 29 May 2015, 07:25:19 pm »
so yes wrench was in NM ( other scale is inch-pounds..)
and i was using copper grease...
I really am perplexed as to why it happened, but we all know its usally operator error....so i cannot figure out what i did wrong!
Paulfzs
« Reply #10 on: 29 May 2015, 07:26:01 pm »
lucky then!
maybe it was a worn bolt
anutz
« Reply #11 on: 29 May 2015, 07:28:07 pm »
damn lucky - the tinest bit of thread left - i would like to know what happened - it felt like the bolt was twisting when i realised what happened.....exactly the same as the exhaust stud feeling thats what i thought oh no.....and stopped.....but it was too late - literally pinged off....
Paulfzs
« Reply #12 on: 29 May 2015, 07:29:04 pm »
it may have been done it too tight before and you just helped it finish itself off.
anutz
« Reply #13 on: 29 May 2015, 07:30:07 pm »
yes i like that idea - it was like that when i got there - that will do nicely for this one  :b
Andy FZS
« Reply #14 on: 29 May 2015, 07:50:13 pm »
7NM would be for a dry bolt if you put grease on then 7NM on the torque wrench would be greater due to the lower friction due to the grease if that makes sense.
Jules-C
« Reply #15 on: 29 May 2015, 09:13:01 pm »
Need to reduce the dry torque setting by 20% or more for greased bolt but can vary a lot depending on grease and materials.  Sometimes a low torque setting is given then an angular measurement given to avoid the problem so you tighten to 3nm say and then tighten another 30 degrees
anutz
« Reply #16 on: 29 May 2015, 09:50:21 pm »
Jules-C/Andy FZS - understood about the need to consider the effect of grease.....never considered it!
How would you reliably figure it out - is there a chart that shows how certain greases affect the fixings?
anutz
« Reply #17 on: 29 May 2015, 10:34:58 pm »
So can i ask - on bolts such as the suspension clamps, if they are greased - is that advisable or not, i am going to be doing a once over soon before the MOT, not sure wether i should copper grease all threads or not?
Andy FZS
« Reply #18 on: 29 May 2015, 10:51:07 pm »
Sorry I can't really advise on % of torque if greased.  I often put grease etc on bolts and seldom use a torque wrench. I tend to just nip things up until they're tight dependant on size. Not really helpful I'm afraid.
anutz
« Reply #19 on: 29 May 2015, 10:58:53 pm »
nah its ok m8 don't expect it, i have copper greased the threads on the yoke bolts and tightened them to recommended torque, will re-consider
limax2
« Reply #20 on: 29 May 2015, 11:14:26 pm »
This was put on a previous topic on here and may be of interest   http://benmlee.com/4runner/threads/threads.htm
But for those bolts I always go by feel anyway.
anutz
« Reply #21 on: 29 May 2015, 11:19:03 pm »
hmmm i think i may be spending my weekend cleaning some bolts and re-doing them without the copper grease.... :lol
« Reply #22 on: 30 May 2015, 07:47:05 am »
http://foc-u.co.uk/index.php/topic,15140.msg171589.html#msg171589
I will say again, personally i think Copper Grease is great stuff BUT these thoughts also make sense too, so for lighter torque settings use the "nip up" technique, but for heavier stuff use oil.
I handle film cameras on a daily basis so i nip up tiny screws that if you blink you could drop them and never ever see them again, so i've never been heavy handed anyway.
anutz
« Reply #23 on: 30 May 2015, 08:02:08 am »
thanks, i think for the high torque bolts i will clean them and torque them dry.....i.e. suspension clamps and axels etc...
other bolts i will just get used to nipping up...
anutz
« Reply #24 on: 30 May 2015, 11:31:48 am »
OK so just cleaned some bolts and reset them, i actually used no torque wrench for the first tighten and went by feel on the Upper and Lower yokes for the forks, and the axel and pinch bolt, turns out by feel it usually pretty close to the suggested torques.....so happy with that...
