Date: 09-05-26  Time: 16:08 pm
Author Topic: How to check rear shock life ?  (Read 3052 times)
Tubz1983
« on: 24 May 2015, 11:29:49 am »
What is the best way to test if the rear shock is knackered? I had a pillion and as soon as he got in the back it sunk right down ? Is that normal ?!!
rhinoeli
Re: How to check rear shock life ?
« Reply #1 on: 24 May 2015, 12:01:51 pm »
You are aware of the spring preload is adjustable right?
Tubz1983
« Reply #2 on: 24 May 2015, 12:21:50 pm »
Ah, I was under the impression they were fixed like the forks?
anutz
« Reply #3 on: 24 May 2015, 12:44:01 pm »
you should have a C spanner in your tool kit to adjust this, there is also an extension bar in there as its neigh impossible without the leverage to move it, mine was very stiff indeed....
« Reply #4 on: 24 May 2015, 12:44:38 pm »
If it's the original shock on a 16-17 year old bike then chances are it's seen better days.
Mine leaked, and i was riding on the spring for a while, which is like riding in the wet with a rear bald tyre.
anutz
« Reply #5 on: 24 May 2015, 01:23:19 pm »
i intend to replace mine with an R6 shock with the help of Kebab19 on this forum when i get the money - and have lost some weight.....not sure which will happen first....if i have no money then maybe i won't eat....  :lol
Tubz1983
« Reply #6 on: 24 May 2015, 01:44:11 pm »
Increased the pre-load a couple of notches so il see how that feels, no extention needed as it wasn't too stiff really :)
paulchucky
« Reply #7 on: 25 May 2015, 08:12:35 am »
original shock is poooooh
upgrade is a must  :)
sinto
« Reply #8 on: 25 May 2015, 08:37:53 pm »
Sounds a bit dodgy if you didn't use the extension handle to help move it especially if you increased the tension on the spring :(
That's maybe why it went down so far in the first place, I'd get that checked out :)
paulchucky
« Reply #9 on: 25 May 2015, 08:46:56 pm »
if your anywhere near me pal i`ll check it out for you  :)
