Date: 10-05-26  Time: 00:46 am
Author Topic: New Renthal bars - brake reservoir on a jaunty angle - bad?  (Read 3772 times)
Arfa
Just swapped on some Renthal 758 bars. All good, however the brake reservoir is now on a jaunty angle, leaning in towards the yoke. I was under the impression that this should be kept fairly level. So, am I likely to hit any issues, other than it being a pain to gauge fluid level?
Punkstig
Re: New Renthal bars - brake reservoir on a jaunty angle - bad?
« Reply #1 on: 21 May 2015, 09:49:10 am »
Shouldn't be a problem as when the bike is put on the side stand the standard reservoir can sit at an angle depending on the angle the bars are left turned!
stevierst
« Reply #2 on: 21 May 2015, 12:42:05 pm »
You go round corners at 40+°, brake and occasionally (unintentionally ofcourse) pull wheelies, and your brakes still work.
I'm pretty sure it'll cope if it's got the correct amount of fluid in it.:P
Inertia_v1
« Reply #3 on: 21 May 2015, 01:04:56 pm »
I have renthals too and it sits at quite an angle, hasn't caused any issues. The only problem I have is my grip hits the fairing on right turns and applies the throttle lol, makes me look a bit of a tool sometimes lol
Derpdiherp
« Reply #4 on: 21 May 2015, 02:10:35 pm »
Out of curiosity, which renthal bars have you fitted? Lower or higher angle?
Arfa
« Reply #5 on: 21 May 2015, 03:35:27 pm »
I've put on the 758 Ultra Low ones. Seem OK, but not been out on bike yet, still got other repairs todo. Compared to stock they are lower and slightly wider.
noggythenog
« Reply #6 on: 21 May 2015, 03:46:36 pm »
I had 758 on my 600 without any hassles, they were nice because they were longer than standard.
Ive got mahhhhoooosive renthals on my thou now and you can see the jonty angle of the resorvoir....ive just done about 60 mileshassle free with it.
mickvp
  • Global Moderator
« Reply #7 on: 21 May 2015, 04:43:42 pm »
Wait, what? You did 60 miles noggy?? How by is your driveway??? :lol
noggythenog
« Reply #8 on: 21 May 2015, 04:50:53 pm »
It took a few laps of the cul de sac to get those 60 miles right enough
As of today ive even got mot Mick.......very posh indeed 8)
Inertia_v1
« Reply #9 on: 22 May 2015, 11:58:31 am »
Low and wide, really wide
