Date: 10-05-26  Time: 05:43 am
Author Topic: Throttle cable rubber cover on handle bars  (Read 2545 times)
Arfa
« on: 20 May 2015, 09:35:01 pm »
On the throttle cables just before they go into the throttle grip on the bars, there's a little rubber cover for the join between the metal housing and the two cables the come off from it. I've gone and shredded this on my last off. Picked up a whole throttle cable assembly off ebay cheap, but I can't see how I can swap over this rubber cover on it's own, there's just too much plastic cable guides and stuff in the way to slide it off. Am I being daft, or do I really need to swap the entire length of the throttle cables to change this rubber bit?
Punkstig
Re: Throttle cable rubber cover on handle bars
« Reply #1 on: 20 May 2015, 10:00:04 pm »
Afaik the rubber part you are talking about comes with a new cable, genuine are just over £40, pattern is £20 both from wemoto!
http://www.wemoto.com/bikes/yamaha/fzs_600_fazer/98-99/picture/throttle_cables_set_a+b_push_and_pull_-_slinky_glide/
noggythenog
« Reply #2 on: 20 May 2015, 10:01:38 pm »
Yep...comes as a complete item im afraid......i only know coz i did the one on my thou recently......i scuffed my 600 one but that didnt matter and i just taped around it as a bodge.
Arfa
« Reply #3 on: 21 May 2015, 08:43:14 am »
Fair enough, just as I expected. Swap whole cable it is then.
