Date: 17-03-26  Time: 17:59 pm
Author Topic: bridgestone bt023 road noise...  (Read 8368 times)
Mike01
« on: 16 May 2015, 09:46:05 am »
Good morning all!
So i have the above on my 600, only had the bike and my licence a short while.. Anyhow the noise that i can only presume is coming from the front tyre is
very loud, i have checked everything i can and am certain its the tyre (grumbly road noise not squeeks etc). It changes depending on road condition, obviously bad road - louder  ;)
I get a low tone rubbing noise when free wheeling the bike out of my garage, was never worried about it as thought its just the pads sat against disc(?)... Wheel has no wobble and spins as it should when raised..
I did a search and the BT021 was well known for this problem but cant find anything about the 23 being the same.
So anyone used these, had issues or think it could be something else.
Cheers.
Re: bridgestone bt023 road noise...
« Reply #1 on: 16 May 2015, 10:08:43 am »
As you've said probably the front tyre starting to square off. Possibly gone hard due to its age so check the tyre date.
Also check to see if you've lost any wheel balance weights.
Good luck fella.
Mike01
« Reply #2 on: 16 May 2015, 10:33:19 am »
Good luck fella.
Thanks mate, never thought of checking tyre age as they look so new/fresh if you know what i mean  :D They dont look to be squared off but could be old as bike only done just over 9k miles.
Will check weights too but dont remember seeing any, i take it they would be the same type used on car tyes, on the rim?
Cheers.
« Reply #3 on: 16 May 2015, 01:56:58 pm »
My front is a newish BT023, i have very sensitive hearing but not noticed any noise at all to be honest.
Mike01
« Reply #4 on: 16 May 2015, 02:50:48 pm »
Just checked and mine are only 16 months old, done around 1500 miles. I did 1k of those in 2 months!!
Oh well maybe have a chat with the local bike garage see what they think.
« Reply #5 on: 16 May 2015, 02:57:48 pm »
Not had a new chain recently, or moved the rear wheel at all?
Mike01
« Reply #6 on: 16 May 2015, 03:00:23 pm »
Nope, fairly convinced it's coming from the front though. Could be wrong  :)
sinto
« Reply #7 on: 16 May 2015, 03:01:04 pm »
Check the tyre pressures properly,  that can make a difference too.
Oh, also check that they are on the right way, I was out with someone years ago and he had his tyres on for months and done quite alot of mileage, but his tyres were both on the wrong way :thumbdown
He was a lucky bunny nothing happened :thumbup
« Reply #8 on: 16 May 2015, 03:05:33 pm »
Presumably it still makes a noise when the clutch is pulled in?
Mike01
« Reply #9 on: 16 May 2015, 03:24:10 pm »
I will check pressures again, last check was 34f 39r I think. Will check rotation marks too  :)
Yes darrsi clutch in makes no difference.
Cheers guys.
« Reply #10 on: 16 May 2015, 03:37:56 pm »
Sure it's not chain noise, rubbing on the plastic chain guide?
Mike01
« Reply #11 on: 16 May 2015, 03:42:49 pm »
Nope, checking now. Tyres right way round, both wheels free moving with no wobbles just the front pads kissing the disc slightly.
Chris
« Reply #12 on: 16 May 2015, 03:47:19 pm »
front wheel bearings? mudguard rubbing somewhere?
Chris
Mike01
« Reply #13 on: 16 May 2015, 03:53:41 pm »
Bearings feel ok, pushed pulled everything and nothing lose or rubbing.
Cold tyre pressure 31f  39r.... front too low, could that cause it...
« Reply #14 on: 16 May 2015, 03:56:47 pm »
Yes, that is low
« Reply #15 on: 16 May 2015, 03:57:23 pm »
I'm running 36/40
Mike01
« Reply #16 on: 16 May 2015, 03:59:16 pm »
I'm running 36/40
Will sort them now, sun's out so will go play for a bit and see  8)
sinto
« Reply #17 on: 16 May 2015, 04:25:38 pm »
Reply #9   by Mike01 on 16 May, 2015 15:24
Post actions
Original tyre pressures quoted were 34f 39r
Think someone has let air out them inbetween posts :lol
Mike01
« Reply #18 on: 16 May 2015, 04:38:16 pm »
Post actions
Yep  :lol
Well has that sorted it.... lol I think so but I now have riding listening for noise syndrome   :rollin
sinto
« Reply #19 on: 16 May 2015, 04:56:54 pm »
Great if that's it :) simple but effective :lol
We all have that! It's called simply 'riding an old bike' :rolleyes
