Date: 10-05-26  Time: 09:37 am
Author Topic: Center Stand clean up...  (Read 12829 times)
anutz
« on: 12 May 2015, 07:40:56 pm »
So i decided to continue taking my bike to bits and cleaning/breaking/fixing bits....center stand is current object of affections....
I made sure i was wearing some goggles in case the spring shot off....
 it was a little tricky to get the bolts off but a quick heat with a torch sorted that - then i had to remove the nuts and then knock one of the bolts out - the one OPPOSITE the side where the spring attaches..
once that bolt was out i wiggled it around a bit till the tension was off the spring and then it fell to bits and i could knock the other bolt out
Here it is before hand:
And...after some attention with wire brush and wire drill bits as well as some degrease....
And
Almost painted it with my exhaust paint i was using at the weekend but then realised how do i take the center stand for a spin  :lol
Any recommendations on what to paint this with?
Anutz
anutz
Re: Center Stand clean up...
« Reply #1 on: 12 May 2015, 07:46:15 pm »
next thing once its painted is also to take care of the rust on the projections it fits to as they are a little rusty and also clean the rest you can see  :lol
Some people a while back commented the center stand can rust badly so this is all in the name of stopping that happening, all seems superficial at the moment
riedrider
« Reply #2 on: 12 May 2015, 07:51:27 pm »
I use for things like that :
And then a top coat of 2K acrylic paint.
« Reply #3 on: 12 May 2015, 08:10:58 pm »
I belive the way to go once your stand is at that stage is to use smooth haherite that paints straight on, my stand is next on my list and at the moment that is what I plan on doing
What de greaser did you use
« Reply #4 on: 12 May 2015, 08:13:27 pm »
Hammerite is a bit thicker and has anti rust properties so I'd tend to slap a load of that on it.
anutz
« Reply #5 on: 12 May 2015, 08:15:44 pm »
degreaser - some left over WD40 Degrease i used on the chain - and then some left over Brake Part cleaner - both very volatile and seemed to cut through the muck...
Then set to work with the wire brushes!
might have some hammerite in the garage....
jimbojim
« Reply #6 on: 12 May 2015, 08:48:41 pm »
I got mine powder coated as well as crash bars as long as its kept clean it'll last years looks better too
anutz
« Reply #7 on: 12 May 2015, 09:07:30 pm »
good idea but i think i will use up the rest of the tin of hammerite i have - no cost and does the job for now  :lol
Punkstig
« Reply #8 on: 12 May 2015, 09:24:38 pm »
Agree with others, hammerite smooth- fyi I've used this on the flaky engine fins and it lasts a couple of years all weather riding! But you've already got heat resistant paint anyway!
anutz
« Reply #9 on: 12 May 2015, 09:28:51 pm »
ordered - will be here tommorow so hopefully more pictures tommorow  :lol
sinto
« Reply #10 on: 12 May 2015, 09:46:02 pm »
Anutz
Yeah, your exhaust paint and stick it in the oven to cure when the wife ain't looking or you'll get some  :uhuh
anutz
« Reply #11 on: 15 May 2015, 10:57:13 am »
Done  :)
2 coats of Hammer....Direct To Rust, Smooth Black....seems ok to me!
« Reply #12 on: 15 May 2015, 11:21:34 am »
Job's a good'un.  :thumbup
sinto
« Reply #13 on: 15 May 2015, 01:18:43 pm »
Looks good anutz, you'll not be far away now that you can actually get it back on the road :-)
« Reply #14 on: 15 May 2015, 01:27:37 pm »
Forget your stand ------------ you need to get some skirting boards on there
anutz
« Reply #15 on: 15 May 2015, 02:19:26 pm »
at the moment i need to pay for all the bike bits, its been a year anyway so whats another few months without carpets and skirters  :lol
Hoping to get this bike back on the road soon...
Still to do...
1. Fit Braided Lines
2. Fit Calipers, this is the issue, the pistons and seals form the USA will not be here till June 11th, and then i probably won't get the serviced calipers back from Powerhouse for a week ( sending the lot to be fitted as well as the rear FZ1 from the USA to be serviced as well....good price! )
3. Fit KOSO Digital Speedo i have purchased - scratching my head on this right now so threads to come!
4. Fit New Lights/Indicators, have a nice all in one unit with fork mounts so not too bad...
5. Mirrors, fit em
So all in all i suspect i will be back on the road June sometime - so plenty of nice riding weather left...
As long as it passes its MOT which will be due June 12th
Dave48
« Reply #16 on: 15 May 2015, 02:57:48 pm »
All good stuff! Have you kept a tally of what youve spent so far? It must be a fair bit so we are looking forward to seeing the end result!
anutz
« Reply #17 on: 15 May 2015, 03:52:13 pm »
i think including the new end can i bought and lots of tools its nearing 900-1000£ so a bit of a whack!  :eek
But i ain't got nothing else to keep me out of trouble and i think it will turn out nice  :)
sinto
« Reply #18 on: 15 May 2015, 05:51:18 pm »
No comment :rolleyes :rollin
greg1953
« Reply #19 on: 15 May 2015, 06:09:59 pm »
Mine was a mess also, took it to Romax in Stockton who powder coated it for £14, it looks better than new.
Greg
« Reply #20 on: 15 May 2015, 10:19:45 pm »
i think including lots of tools
You cant count them as they will / should last you forever on other stuff and bikes
« Reply #21 on: 15 May 2015, 10:23:30 pm »
Greg
I might get mine powder coated -- but how much better is powder coating than smooth hamerite UNLESS you can send them your crabby old stand and THEY do all the cleaning too. Do they or do you have to clean it up (to a certain extent first ).
Do they do some sort of acid bath or shot blast first -- if so then sounds good
anutz
« Reply #22 on: 15 May 2015, 10:30:06 pm »
The only downside to the hammerie i find is that it takes the brushes you use to the grave.....never been able to clean them up
anutz
« Reply #23 on: 15 May 2015, 10:40:20 pm »
See my pic above of the underside of the bike and the mount points for the stand, should i put some hammerite on any bits there???
It would stop any more ingress of crap into any areas already flaking...?
« Reply #24 on: 16 May 2015, 07:54:02 am »
The centre stand just sits there and gets shit thrown at it constantly (if you ride in all weathers), so personally i'd stick with a good thick layer of Hammerite over powder coating any day.
