Date: 11-05-26  Time: 04:21 am
Author Topic: Problem with chain adjustment  (Read 7616 times)
Derpdiherp
« on: 09 May 2015, 11:33:35 pm »
So today I've changed the chain and sprockets on the old fazer. I'm not sure if this was happening before I did this but something weird is going on.
To move the right hand side of the wheel back when the axle is all loosened, I have to loosen off the torque arm as well for it to move - is this normal? Any ideas what could've happened if it isn't?
Re: Problem with chain adjustment
« Reply #1 on: 10 May 2015, 12:23:49 am »
Not sure what you are asking, quite -- but you dont just adjust one side you do both sides the same amount to pul the wheel back
Derpdiherp
« Reply #2 on: 10 May 2015, 12:37:40 am »
Yeah. I'm saying that once it's loosened (both sides) the right hand side will not move unless I undo the torsion bar which attaches to the brake caliper - then the back wheel moves freely.
Any ideas?
« Reply #3 on: 10 May 2015, 01:16:51 am »
search this forum for brake caliper torque arm
Derpdiherp
« Reply #4 on: 10 May 2015, 01:35:52 am »
Thanks. I didn't get any results though, perhaps you could link to what you're referring to?
« Reply #5 on: 10 May 2015, 09:23:28 am »
Yes, that is normal.
The swingarm, caliper mount and torque arm are a triangle. If you change the length of one of the sides the angles have to change too.
If you don't loosen off the joints it puts strain on them and the weakest can fail as happened on Kebab19's bike last year.
« Reply #6 on: 10 May 2015, 09:28:26 am »
Loosen whatever needs loosening.
Take your time nipping up either side so the markings are spot on, then worry about the torque arm afterwards.
Your main concern is the spinning of the rear wheel and listening for any nasty noises.
It should spin with minimal fuss, indicating that the wheel is aligned properly and the chain is not chomping itself to bits trying to realign itself because it's offset.
You'll hear if it's wrong, and even if you're deaf, you'll feel it if it's not correct through the left footpeg when riding it.
« Reply #7 on: 10 May 2015, 09:33:16 am »
Don't over tighten it either, around 35mm play on the middle lower part of the chain.
It's easy to think you have it right then move the wheel a couple of mm and it can really tighten it up.
Take it for a spin to feel if all is okay, then on return give the chain a good spray with lube while it's still warm.
Derpdiherp
« Reply #8 on: 10 May 2015, 05:49:16 pm »
Thanks for the help guys. I was just confused because there was nothing in the haynes manual about having to loosen it before adjusting your chain, but after having the rear end apart to change the chain and sprockets it made sense that you'd need to.
Makes me cringe thinking that I never used to do it!  :eek
Derpdiherp
« Reply #9 on: 10 May 2015, 07:05:15 pm »
Quick question, I've never been too sure of exactly how tight the chain should be. When you say 35mm play - do you mean if you lift the chain there's 35mm, or do you mean if you push the chain up and there's 12.5mm and push the chain down and there's 12.5mm that's right?
« Reply #10 on: 10 May 2015, 10:50:23 pm »
That actually adds up to 25mm.  :lol
35mm in total, it'll be at its lowest point anyway.
His Dudeness
« Reply #11 on: 11 May 2015, 10:54:37 am »
Flex it up and down and the total movement should be 35mm (or whatever it should be I can't remember :lol)
« Reply #12 on: 11 May 2015, 11:42:51 am »
The loosening of the torque arm marlaky was discussed here some time ago and I think the outcome was to do it to be safe - but like you say there is no mention of it in the manual.
But if you do not know the history of the bike then you do not know if the bolt has been replaced and it has been done up too tight before because when done properly you should not need to loosen it because the caliper should rotate and the arm then pivot as the wheel is moved back.
But no harm will be done by loosening whereas there is a chance of harm by not loosening.
« Reply #13 on: 11 May 2015, 12:51:29 pm »
 :lol
Jamieg285
« Reply #14 on: 11 May 2015, 01:33:34 pm »
I may be wrong, but I thought that the torque arm was supposed to pivot, otherwise it will bind and work against the suspension movement.
Based on this theory, you shouldn't have to loosen it to adjust the chain, however, when you find yourself in this scenario, remove, clean and lubricate the torque arm so that it moves properly.
Jules-C
« Reply #15 on: 11 May 2015, 01:33:58 pm »
Or if you don't have enough spare hands to hold ruler steady while pushing chain up and  down adjust it so it doesn't quite touch swinging arm when pushed up and you won't be too far off.
I think later models handbook changed it to 45mm
« Reply #16 on: 11 May 2015, 01:45:48 pm »
The torque arm would only need to pivot if the front end is fixed to the frame, on the Fazer it attaches to the swingarm so doesn't need to allow for suspension movement.
« Reply #17 on: 11 May 2015, 01:57:24 pm »
  :agree I agree with this
That is also right - the pivoting of the arm and the rotating of the calaper comes into play when the wheel is moved back.
Look at the bolts - they are designed so that the thread ends before you can tighten up too much arnt they ?
Jules-C
« Reply #18 on: 11 May 2015, 02:03:55 pm »
The bolts should have sufficient length of thread that they clamp properly on to the swinging arm and brake bracket.  The smooth unthreaded section is to spread the load from the torque arm over that length of the bolt and not just the high points on the thread
His Dudeness
« Reply #19 on: 11 May 2015, 02:10:16 pm »
Don't see how it has anything to do with suspension movement. It's fixed to the swing arm and goes through the caliper bracket which is around the axle which is fixed. There's no movement in the torque arm other than when you're moving the wheel to adjust the chain. It has to be able to pivot at one end a little because it forms a triangle and the angles change as the wheel is adjusted back and the triangle flattens. You don't really notice it until you put a new chain on and it has to move a lot in one go. I'm blaming Pythagoras for all this :lol
« Reply #20 on: 11 May 2015, 02:59:41 pm »
Flex it up and down and the total movement should be 35mm (or whatever it should be I can't remember :lol )
You think ???
« Reply #21 on: 11 May 2015, 03:19:35 pm »
All I keep reading everywhere after a quick search is 30-40mm.......or.......35mm.
45mm is just too much in my opinion.
Derpdiherp
« Reply #22 on: 13 May 2015, 02:46:47 pm »
So.. Err.. The consensus is the torque arm should be fitted fairly loosely - or at least loose enough to allow the brake to move backward with the wheel when adjusting the chain?
I can't see much harm in having it nipped up to being pretty solid - as has been said it shouldn't move except for when you adjust the chain / fit a new chain.
Edit - Only reason why I'd prefer to have it nipped up fairly hard is the fact that that is all that is stopping the rear brake from going on a whirlygig round the brake disk! Or at least moving a little horizontally.
Jules-C
« Reply #23 on: 13 May 2015, 04:28:57 pm »
Torque are bolts slackened so loose while adjusting chain but tightened to correct torque (or fairly tight using ordinary spanners) before riding bike again.
Jules-C
« Reply #24 on: 13 May 2015, 04:33:41 pm »
I'm not recommending 45mm but page 6-28 of 2003 manual says 30-45mm
The same page also says replace your brake seals (including master cylinder) every 2 years.
