Date: 11-05-26  Time: 01:52 am
Author Topic: How do i detach the headlight wiring loom....  (Read 5819 times)
anutz
« on: 09 May 2015, 05:26:52 pm »
So simple question, it looks obvious, unwind the tape or cut it?
I don't see any other way, there is a similar holder on the main wiring loom as well under thank....am i missing something of i just cut/un-wrap?
sinto
Re: How do i detach the headlight wiring loom....
« Reply #1 on: 09 May 2015, 05:51:56 pm »
What you trying to do anutz? Follow the wires back to under the tank and they should all be in connectors, unclip then undo the cableties etc bavk to headlamps etc and that's you got it out in one piece :)
anutz
« Reply #2 on: 09 May 2015, 06:13:32 pm »
i am taking the front headlights off and the speedo - have a digital Koso one on the way and going to put some dominator lamps on it - i like the streethfighter look more than the faired look and with all i am doing i thought i would just crack on!
sinto
« Reply #3 on: 09 May 2015, 06:56:13 pm »
Yeah I gathered that but you still dont want to just cut right through them?? :rolleyes
If you get the wiring diagram from the download section, you can then use the wiring harness as it's on the bike now, all you have to do then is strip the wires back at some point, solder your new wires to the corresponding original fazer wires and then connect the blocks under the tank, makes for a far better and neater job, but you need to make sure you connect the right wires, you may well have some spare that will need to be capped as well.
Once soldered individually, heat shrink them, then put a cover over the whole lot, and fix them to the frame in much the same way as they are now, will look a lot neater.
Remember if your puting on heat shrink, that has to go on wires first before you solder.
You can get various coverings for the wires once that's all done, but amalgamation tape is probably the way to go, DO NOT USE INSULATION TAPE!  ITS RUBBISH AND WILL DETERIORATE OVER TIME.
rhinoeli
« Reply #4 on: 09 May 2015, 07:17:16 pm »
Pull it upwards!
sinto
« Reply #5 on: 09 May 2015, 07:27:05 pm »
Pull it upwards!
Eh? Are we talking of the same thing? :lol
rhinoeli
« Reply #6 on: 09 May 2015, 08:24:52 pm »
I believe anutz is talking about that little plastic holder thingy clipped on the frame.
sinto
« Reply #7 on: 09 May 2015, 09:02:52 pm »
Phew :rolleyes
Yeah I think so too but it's wrapped with tape I think?
rhinoeli
« Reply #8 on: 09 May 2015, 09:15:00 pm »
The whole thing comes off. There is a little knob on the frame. The plastic thingy clips on this knob. Simply pull upwards to remove it. You do not have to remove the tape.
anutz
« Reply #9 on: 09 May 2015, 09:19:19 pm »
hmmm
i removed the tap for the life of me i could not get it off - will probably just use cable ties - makes more sense to me...
sinto
« Reply #10 on: 09 May 2015, 09:47:34 pm »
Just love our technical use....'thingy' etc :lol
rhinoeli
« Reply #11 on: 09 May 2015, 09:53:28 pm »
As english is not my native language I use 'thingy' frequently...  :lol
anutz
« Reply #12 on: 09 May 2015, 09:55:49 pm »
english is my native language and i use it all the time pal  :lol :lol :lol :lol
sinto
« Reply #13 on: 09 May 2015, 10:06:26 pm »
Scottish is my native language but I have to use English :rolleyes :rollin
sinto
« Reply #14 on: 09 May 2015, 10:08:27 pm »
We understand what your saying rhinoeli and your input is more important than your language :)
