Date: 11-05-26  Time: 08:11 am
Author Topic: clutch slip  (Read 3268 times)
Paulfzs
clutch slip
« on: 05 May 2015, 08:29:04 pm »
bikes been fine untill i did my last oil change now im getting fairly bad clutch slip.
Only way i can remove most of it is to turn the top adjuster all the way in but then the biting point is right near the bar but i still have clutch slip.
Wrong oil?
put in 15/40 semi synthetic
i used 15/40 semi synth before but i different brand and it was fine
Jules-C
Re: clutch slip
« Reply #1 on: 05 May 2015, 09:14:25 pm »
15w is quite thick until engine warmed up and make clutch more prone to slipping. What oil was it? Is it JASO MA, MA1 or MA2 specification?
Re: clutch slip
« Reply #2 on: 05 May 2015, 09:21:53 pm »
Please tell me, why did you not use 10w/40 oil?
Paulfzs
Re: clutch slip
« Reply #3 on: 05 May 2015, 09:32:43 pm »
i had it in my head it was 15/40 it was supposed to have.
XT2000 15W-40
Recommended by Comma for applications requiring: MB 229.1, MB 228.3; VW 501 01, VW 505 00; ACEA A3/B4; API SL CF CG-4
noggythenog
Re: clutch slip
« Reply #4 on: 05 May 2015, 09:40:35 pm »
Did a quick search on google and that looks like car oil Paul, could have friction reducing agents that maybe causing the slip.
Has to be motorbike specific oil rather than just vehicle oil
Paulfzs
Re: clutch slip
« Reply #5 on: 05 May 2015, 09:47:48 pm »
hmm, i used similar from same brand and it was fine,the previous was just coma super semi synth mineral oil... looks like im buying new oil then... or i could try taking out 2l and replacing with 2l of the old oil that i didnt use
noggythenog
Re: clutch slip
« Reply #6 on: 05 May 2015, 09:52:44 pm »
You could do mate but tbh perhaps your bike wasnt running perfectly even with the last stuff if it was just car oil....you maybe just didnt know that it wasnt
Id be tempted to get rid and get down halfords
I got 5 litres of motorbike specific oil 10W40 for about £24....it's at the bike section where they sell the chain lube and oxford stuff etc, not by the rest of the oils in the generic oil section.
If it was me then idrun the new bike oil for a few hundred miles, flush it out and replace again just to try get rid of all those old friction reducers.....or just run it until the next oil is due.
Paulfzs
Re: clutch slip
« Reply #7 on: 05 May 2015, 09:58:53 pm »
can't run this till the oils due, i did 200 miles yesterday and it was painful trying to overtake (may day run) and opening the throttle to see the revs shooting up and going nowhere.
£24!! i paid £26 for this oil. will check out halfrauds.
noggythenog
Re: clutch slip
« Reply #8 on: 05 May 2015, 10:06:14 pm »
This stuff
I did t mean keep running what youve got...i meant run new good stuff and either flush it through again or just run it.
As comparison the castrol super shizny was about £38 for 4 litres.
